  • 2005 - 2009 Specific Tech
basic lowering question
  • Thread starter Thread starter spectre30075
  • Start date Start date Aug 5, 2007
1 of 2 Next Last
spectre30075
39
  • Aug 5, 2007
I'm switching from stock tires on my 05 GT vert to 245/45/17's, and I want to lower the car just a bit, no more than 1". All I need is new springs right? (and an alignment).
lightblade
366
Aug 5, 2007
  • Aug 5, 2007
yes
busterc
12
farmington Missouri
Aug 5, 2007
  • Aug 5, 2007
1 inch isn't much so you could probably get away with tossin the springs on and just driving it.
Once you start going lower, you need to think about some Camber bolts or the Caster/Camber plates to correct the geometry of your suspension.......In other words, you'll totally wear out the inside edges of your tires in no time at all!
I lowered my car 1.75" in front and 2" in back and I recently replace the rear control arms and added the anti squat brackets....It made a big difference in how it rides/handles/launches.....Much better!!
spectre30075
39
  • Aug 5, 2007
Thanks for the help guys.
blacksheep06
288
  • Aug 5, 2007
I say do it right and put some tociko shocks and struts on with the springs. Might as well get an adjustable panhard bar too. You get what you pay for and I wouldn't get cheap with the suspension on a nice car.
LV51FER
318
Caerphilly, Wales, UK
Aug 6, 2007
  • Aug 6, 2007
I agrre with the above. It's such a PITA changing the springs out at the front that you might just as well replace the struts with a decent set. They're down to about $550 for the Tokico D-Specs now.
spectre30075
39
  • Aug 7, 2007
Well I'm confused again now. Would new shocks and struts be necessary? What would be the ramifications of just changing the springs? Also, money is tight...
M
MikeysOTP
203
  • Aug 7, 2007
It really depends on what you are looking to do with the car and what expectations you have from swapping the springs. If you are like me and just looking to lower the car a bit while slightly improving the handling on an everyday driver then go for it. If you are building a car for the track, serious racing, or you just drive really hard on the street and need a big improvement in handling then now is the time to do the struts and shocks. You can save a few bucks by getting a package deal I would imagine. You would also save the four or five hours (that's how long the spring install took me....I am NOT a mechanic by any means) of labor it will take to do the shocks/struts later.
spectre30075
39
  • Aug 7, 2007
I just want to lower the car a little for appearance, no more than 1 inch. I want to switch from the stock 55 sidewall tires to 45, then shore up that wheelwell gap some. Not looking to build a race car..my car will never see a track, but I do engage in 'spirited driving' from time to time. I noticed on another thread where people recommend getting an adjustable panhard bar though, and i'm wondering how necessary that is. If the car is going to be offcentered from the slight drop, even just a little, I'll spring for the adjustable panhard bar. I'm a noob and don't know a lot about this stuff.
M
MikeysOTP
203
#10
  • Aug 7, 2007
  • #10
If my car is off-center even the slightest bit it is news to me. I have looked at it very closely and I can't see any difference from one side to the other at all. The guys at Brenspeed told me that it wouldn't be a problem with these springs and as far as I can tell they were right. Apparently it only starts to happen if you go lower than an inch and a quarter in the rear.
spectre30075
39
#11
  • Aug 7, 2007
  • #11
How much did the Steeda springs lower your car?
M
MikeysOTP
203
#12
  • Aug 7, 2007
  • #12
I didn't measure it ahead of time Kind of wish I did. They claim an inch in the front and an inch and a quarter in the rear and I would say it was at least that much.
McQueens Dream
260
Winston Salem, NC
Aug 7, 2007
#13
  • Aug 7, 2007
  • #13
running 245/45/17's will actually ADD more wheel gap than what came factory, those tires are too short for the newer cars...
spectre30075
39
#14
  • Aug 7, 2007
  • #14
Yeah that's why I want to lower the car, but not a lot. I don't want to have to buy a lot of parts or sacrifice a lot of ride quality, i just want to make up for the added gap i'll get after switching to 245/45's.
McQueens Dream
260
Winston Salem, NC
Aug 7, 2007
#15
  • Aug 7, 2007
  • #15
ok, let me try to sum this up. if you switch to the 245/45's and drop it one inch, it will look exactly the way it does now, only closer to the ground. the tires will still look too small for the car. if you want to fill the fender gap up, switch to 18's or even 20's. i wouldn't go this route to get a "lowered" look, in the end, the car will look worse and ride even worse than the looks. the tires you are going to use are 25.68" tall and the factory tires are 27.12" tall. so that's a difference of 1.44". so even if you lower the car, you would have to drop it an inch and half to make it like factory with the fender well gaps. keep your stock tires and drop it, it will look so much better.
spectre30075
39
#16
  • Aug 8, 2007
  • #16
That's good advice..I think that is what I will do. I would really like to have the wider footprint of the 245's, but I don't want to spend an arm and leg buying all the crap to do it right. Also, I don't want to go with larger wheels.
McQueens Dream
260
Winston Salem, NC
Aug 8, 2007
#17
  • Aug 8, 2007
  • #17
then get some 255/50/17's and be done with it, those are stock height and wider to boot...
blacksheep06
288
#18
  • Aug 8, 2007
  • #18
Yea, what he said is right but I would go for an 18" bullitt rim with 255/45/18 if your going to the expense of new tires. 18" bullitt replicas are actually cheaper than the tires. You can then sell your stock wheels and tires on ebay and cover MOST of the expense of the new wheels. That's what I did anyway.
My car rides great with these wheels/tires and the steeda ultralite springs. I don't notice much of a difference at all from the stock suspension and tires. And the car looks and handles much better. But the d-spec shocks/struts may be what's making the car ride so good.
spectre30075
39
#19
  • Aug 8, 2007
  • #19
Good suggestion McQueen..that never even occured to me. If the chart I found online is correct, the height of the stock tire is 27.18", and the height of a 255/50/17 is 27.04"..barely over a tenth of an inch difference, I can live with that. I'll probably still get some springs if I can find any that will only lower 3/4" to 1", and no more.
Also, are there any potential problems with 255's on stock wheels?
spectre30075
39
#20
  • Aug 8, 2007
  • #20
That's a cool idea but honestly I wouldn't want to go through the hassle of selling the stock wheels, lol, plus I like the idea of having the lighter 17's anyway.
1 of 2 Next Last
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
C
New member from NJ
  • Calyp5.0
  • Sep 25, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 25, 2026
General karthief
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
