  • 1994 - 1995 Specific Tech
Basinnia Header gaskets?
  • Thread starter Thread starter 95GTvert[bv12]
  • Start date Start date Apr 6, 2004
95GTvert[bv12]
1,792
Lake Tahoe, NV
Apr 6, 2004
  • Apr 6, 2004
Ok i am installing a new exhaust this weekend and i need recomendation on what header gaskets to get.
They are basiani equal lenth headeres and off road x-pipe
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Apr 6, 2004
  • Apr 6, 2004
I've tried copper, and multi-layer dead-soft aluminum, and Fel-Pro 1415's. The only gaskets that didn't leak were the Fel-Pro 1415's...
Dave
VIPERn94Five-0
3,352
Poughkeepsie, NY
Apr 6, 2004
  • Apr 6, 2004
you can order new ones from Bassani...they are stainless i believe supposed to be totally reusable...they are like $40 a piece though...im running 1415's with no probs!
Anthony
95GTvert[bv12]
1,792
Lake Tahoe, NV
Apr 6, 2004
  • Apr 6, 2004
I will just use the fel-pro
S/CBlack95GT
2,018
Tampa Palms, FL
Apr 6, 2004
  • Apr 6, 2004
For $15 you can't beat the 1415s, they are great. Have fun with those headers, they are HUGE and require the engine to be unbolted from the mounts. It also helps to remove the upper intake.
95GTvert[bv12]
1,792
Lake Tahoe, NV
Apr 6, 2004
  • Apr 6, 2004
yeah i am going to need all the luck i can get i plan on doing the install in a few hours...i am going to try to install them from bottom up so i dont have to worry about the upperintake
VIPERn94Five-0
3,352
Poughkeepsie, NY
Apr 6, 2004
  • Apr 6, 2004
it aint gonna happen....the driver's side will go in if you unbolt the steering shaft...but the passenger side just isnt gonna work...there is NO ROOM....you will HAVE to unbolt the motor mounts and jack up the motor to get the passenger side in....oh and make sure when you disconnect the steering shaft to slide that puppy in there if you tuck the steering shaft up and to the side along the inner fender that once you get the header in theryou get the steering shaft beneath the header before you bolt the header to the head...cuz you will never get the shaft down if you dont <----trust me...you dont wanna find that out and have to go back and take the header off....but the dirver's side is a PITA!!....just undo the mounts and jack up the motor right from the start i actually got the passenger side header wedged between the little "lip" on the valve cover and the inner fender...it was stuck so bad it would not budge no matter what i tried...it stayed like that for a whole day while i was pissed at the car. All this because i didnt want to take the time to undo the mounts and jack it up. But then i finally jacked up the motor and it went in fairly easily after that....
Anthony
T
Touring23
294
Washington
Apr 6, 2004
  • Apr 6, 2004
FWIW I have the Bassani shorty equals. I used their gasket; it was slow to seal but works fine now.
I didn't need to unbolt the steering shaft for the LS, but I did need to loosen the RS motor mount and raise the engine for the RS. Beaucoup wrestling with the EGR at the header. Anthony's post is on target, pack the Excedrin.
Reckon I should mention, mine had a weld missing where the four primaries join at the collector. Looking into the collector I could see daylight. Sent it back and they exchanged it pronto with apologies. That was nearly a decade ago, things are probably different now. Good luck!
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
W
Dipstick
  • wccurtis1963
  • Jun 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
Willybill32
R
5.8 Trinity in a foxbody
  • Ron_ronb
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
4v cobra exhaust compatibility
  • Kid wita 5oh
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 30, 2026
squeak93
