bassani catback install question
V8SRGRT
70
MI
Hey....you guys who have installed a bassani aftercat.... did you have to disconnect the lower fastners on the shocks to lower the axle or can it be installed without disconnecting anything???? I have a 2004 GT...thanks
Tim2002GT
635
Tulsa, Oklahoma
On my '02, i had to unbolt the bottom of the shock to let the axle down enough to fit the tailpipes over. I tried for about 10 minutes to get it over without doing this, but couldn't get it to fit over the axle. Don't worry, it is pretty easy to bolt it back up!
Superhereaux
chicks make me feel inadequate
538
South Texas
for the install take the rear wheels off and you'll have all the room in the world without disconnecting a thing
if you're talking about removal of the stock piece just cut the ****er off
Roos85
125
Maryland
If your talking about getting the old one off then just cut it, i put a loudmouth on mine a few weeks ago and I just cut it off. not worth keeping really. Maybe the tail pipes but I garbaged it all. As to putting the new one on, are the tips already welded to the pipes that go over the axle? If so, you will need to let the rear axle down to get it over.
