Bassani Exhaust Video!!!
i checked their website, they have two cat-backs: the "BX" and the "Street Competition". the descriptions were the same so i dont know what the differences are. whatever you have sounds bad ass man !
EDIT: ok i figured it out. the "BX" cat-back is the same thing, just aluminized steel pipes instead of full strainless steel like the "street comp" cat-back.
JeeTee said:
okay if i were to buy this for my 04 GT with the oxygen sensor extensions what else would i need to get it going ??
http://www.ninosport.com/index.asp?PageAction=VIEWPROD&ProdID=31
Actually since it's just and o/r midpipe, you would need a pair of MILs to eliminate the check engine light. Extensions are only needed on LT headers. So that's it. Since you have an '04, should be able to use the stock gasket on the passengers side.
**edit. Just noticed that it's the high flow cat one, so you don't even need the MILs.
He'll need the 02 extensions. Ford relocated the rear sensors on all '04's. Any aftermarket H or X-pipe will need them.
Yea I really like it! Well worth the money. It is loud for catted. Here in Delaware emissions is strict and I actually failed when I went through with the baffles in I was like 2 db over and the guy was a ---- so I went home and stuck some steel wool behind the baffles and put up a wire mesh screen to hold it in. It sounded Stock!! The recheck guy said have a nice thanksgiving and let me go without checking anything! It is a good quality exhaust system and I have put a guy with flows to shame as well haha it's nice!
