Battery Cut Off Switch
  • Thread starter Thread starter Black 93 Fox
  • Start date Start date Jul 9, 2005
Black 93 Fox
1,995
Vancouver,Washington
Jul 9, 2005
  • Jul 9, 2005
I already Have the battery relocated and wired up too the switch. Everything works fine except when the car is running and i hit the switch the car keeps running. I did a search and found that i need to wire the alt wire to the postitive side of the switch. For right now is it safe with the wire from the swtich coming up to the soleniod and not having the alt wire wired to the back where the switch is. Also is my battery still getting charged wired like this i plan to change it but if i dont have to right now i wont.
Thanks for the info.
hllon4whls
BANNED
2,567
Covington
Jul 9, 2005
  • Jul 9, 2005
Its safe, just not track legal.
Black 93 Fox
1,995
Jul 9, 2005
  • Jul 9, 2005
Thanks do you also know if the battery still gets charged this way?
whtpny
338
Spokane WA.
Jul 9, 2005
  • Jul 9, 2005
As long as the alternator is connected to the solenoid and the POS battery cable is connected to the solenoid also then yes. You can check by checking battery voltage while not running then start the car and it should be at least 13v or higher if you have a better than stock Alt.
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
