Battery Cut Off Switch ?
Killa
1,006
56
49
My car is rarely drive , 1 a month, and my aftermarket alarm is draining the battery.
I wonder its possible to install a battery cut off switch inside the car ( inside arm rest ), can any one shine me a light , on where to begin, where to buy the switch.... and how to install the switch.. thanks
Yes, this is absolutely possible. You could look into something like this...
http://www.prioritystart.com/
I'm not advocating this particular brand, there are several systems like this. Basically, once you hit a low threshold (11.7v in this case) it automatically disconnects the battery from further discharge.
If you just want a manual disconnect switch, that has been done on race cars for years as a safety consideration.
Something along these lines...
http://www.summitracing.com/parts/mor-74101/overview/
Plan A:
Typically it is something draining the battery. Small things like glove box or courtesy lights are often the culprits. If you have an aftermarket stereo or alarm system, it is also suspect.
The ideal method is to disconnect the negative terminal, and connect a Digital Multimeter (DVM) between the negative terminal on the battery and the negative cable. Set the DVM on a low current scale of 2-5 amps if it doesn't auto range. Watch the current draw, and then start pulling out fuses. When you see a sudden drop in the current, that circuit is the likely culprit. Note that the computer, radio & clock will draw less than 1/10 amp to keep the settings alive.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf. You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
If you can’t find the current drain by pulling fuses, then the alternator is suspect or any aftermarket sound or lighting equipment that may be on the car. Disconnect the alternator output power plug, then disconnect any aftermarket sound or lighting equipment while watching the current on the DVM.
Plan B:
For a battery cut off switch, see http://www.moroso.com/catalog/categorydisplay.asp?catcode=42225
is the switch http://www.moroso.com/catalog/images/74102_inst.pdf is the installation instructions.
Use the super duty switch and the following tech note to wire it and you will
be good to go.
Use the Moroso plan for the alternator wiring and you risk a fire. The 10 gauge wire they recommend is even less adequate that the stock Mustang wiring.
There is a solution, but it will require about 40' of 18 gauge green wire.
Wire the battery to the two 1/2" posts as shown in the diagram.
The alternator requires a different approach. On the small alternator plug there is a green wire. It is the sense lead that turns the regulator on when the ignition switch is in the run position. Cut the green wire and solder the 40' of green wire between the two pieces. Use some heat shrink to cover the splices. See http://fordfuelinjection.com/?p=7 for some excellent help on soldering & using heat shrink tubing.
Run the green wire back to the Moroso switch and cut off the excess wire. Try to run the green wire inside the car and protect it from getting cut or chaffed. Crimp a 18 gauge ring terminal (red is 18 gauge color code for the crimp on terminals) on each wire. Bolt one ring terminal to each of the 3/16" studs. Do not add the jumper between the 1/2" stud and the 3/16" stud as shown it the
Moroso diagram.
How it works:
The green wire is the ignition on sense feed to the regulator. It supplies a turn on signal to the regulator when the ignition switch is in the Run position. Turn the Moroso switch to off, and the sense voltage goes away, the voltage regulator shuts off and the alternator quits making power.
The fuse & wiring in the following diagram are for a 3G alternator. The stock alternator uses a dark green fuse link wire that connects to 2 black/orange wires. Always leave them connected to the starter solenoid even if you have a 3G alternator.
attachment.php
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring
http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
I have been there myself. Drive one of my cars like once a month. I don't think a battery cutoff is the answer. Not sure what all you have hooked up to it, but if you disconnect it, lots of things have to reset. And really, even if nothing is draining the battery, it will still go dead. I ended up using a charger maintainer. It will keep up with small drains like an alarm. This is just like the one I bought:
http://www.snapdistributors.com/yuasa-smart-shot-900-battery-tender-charger-maintainer/
I have also heard that battery tender makes one too....
http://www.grainger.com/product/10W...0W823&ef_id=UwvZdAAABX@6qc-Z:20140225001612:s
I don't know, just seems a lot easier then trying to get in do a lot of rewiring.
