  • 1994 - 1995 Specific Tech
Battery dies weird!!!! Help please
  • Thread starter Thread starter Guero
  • Start date Start date Mar 18, 2007
Guero
2,148
Mar 18, 2007
  • Mar 18, 2007
Well i was driving around and i noticed my lights getting dimmer and dimmer, then my rpm's dropped to zero(stopped working), but the car was still running, then the mph did the same. I stopped at a gas station. To look around but nothing. I started it but it barely started. I got home turned it of and tried to start it and nothing just the sound of a dead battery. What the hell can be wrong? The alternater??? Battery is brand new!!!!
sage2k
645
Baton Rouge, LA
Mar 18, 2007
  • Mar 18, 2007
might be the alternator, get it checked out
J
JJs89lx
39
  • Mar 18, 2007
Had the same problem..... My battery was new and my alternator was new.... My problem.......... Had a bad wire! just check your wires and alternator
trav_19
810
Jackson, MI
Mar 18, 2007
  • Mar 18, 2007
sounds like a atl to me when they go bad they drain everything from the battery when mine died in my old sunbird i was driving back from work a hour drive and i watched it get low then all the gauges started going crazy
Guero
2,148
Mar 18, 2007
  • Mar 18, 2007
Thanks Guys! Ill take of the alternater and have it checked but before i will defitnetly look for a bad wire
1TallMF
955
Montreal
Mar 18, 2007
  • Mar 18, 2007
Yup. Car was running off of the battery. Check your connections at the alternator, and for continuity accross the charge cable that runs from the alternator to the distribution box. If that all appears normal have the alternator bench tested.
edit: oopsy. your post poped-up while I was writing this.
Guero
2,148
Mar 18, 2007
  • Mar 18, 2007
yes sir! Last night i did check the connections to the Alternater. they seemed fined, but then again i missed when the CAI fell of and the car wouldn't run
HISSIN50
34
129
Mar 18, 2007
  • Mar 18, 2007
After the battery charges (while you're at the parts store having the alt bench tested) check battery voltage with the car off vs with the car idling. Car off should be 12.6 volts or so. Car idling should be 14.4 volts at first, and then no lower than ~13.6 volts.
If the alt tests good but there's no output, check the alt fuse (underhood fuse box) and the fusible links for the alternator (on the side of the PS bracket, just under some wire loom).
When checking connections, dont forget arguably the most important one on the car that's most overlooked - the PDC connection.
Good luck.
Guero
2,148
Mar 18, 2007
  • Mar 18, 2007
PDC???
HISSIN50
34
129
Mar 18, 2007
#10
  • Mar 18, 2007
  • #10
Power distribution Center. It's the clump of big wires on the side of the underhood fuse box. The battery, alternator and power to the rest of the car need this connection to be in great shape or all sorts of issues arise (it's the equivalent of the starter solenoid battery lug on a fox III, for the old fox guys).
Good luck.
Guero
2,148
Mar 18, 2007
#11
  • Mar 18, 2007
  • #11
Well it was a gay ass fuse!!!!!!!!!! Switched it went for a drive, had a little problem while i wasdriving the first 5 minutes or less. Then it started working like normal again!!!!!!!!!!!!YAY!!!!!!!
HISSIN50
34
129
Mar 19, 2007
#12
  • Mar 19, 2007
  • #12
You should always use blade-style fuses instead of whatever kind it was you had in there before.
Seriously, glad to hear you got it fixed.
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
