someone gave me some advice on it before, but i think it got deleted
i forget how to use the test light to see where the drain is
is it, disconnect the ground from the battery and clip the light to the pos terminal - then touch the ground battery terminal with the light - if it lights up, you have a drain?
the battery stopped draining after i disconnected the stuff on the positive side of the solenoid (except for the battery cable)
