Battery Draining
bigcahoona
74
Chi Town
I was wondering if anyone might have a quick easy way to check what could be causing my battery to drain over night. The last couple of days I drove the car all day and night with no problems at all starting. I let the car sit over night and it's a slow crank. One year old Optima battery, one year old 3G alt. (88 5.0) What test is the best. Oh and I haven't done any new upgrades since the new bat & alt.
Typically it is something draining the battery. Small things like glove box or courtesy lights are often the culprits. If you have an aftermarket stereo or alarm system, it is also suspect.
The ideal method is to disconnect the negative terminal, and connect a Digital Multimeter (DVM) between the negative terminal on the battery and the negative cable. Set the DVM on a low current scale of 2-5 amps if it doesn't auto range. Watch the current draw, and then start pulling out fuses. When you see a sudden drop in the current, that circuit is the likely culprit. Note that the computer, radio & clock will draw less than 1/10 amp to keep the settings alive.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf. You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
