Battery Relocation help
  • Thread starter Thread starter Jaymes
  • Start date Start date Jul 31, 2004
J
Jaymes
11
  • Jul 31, 2004
Hey Everybody,
I just bought a battery relocation kit to move my battery to the trunk. Has anyone done this before? I was going to put it on the passenger side of the trunk. Does anyone have instructions for mounting it properly? How did you run the positive cable through the car? ON the outside of the car or did you run it through the inside of the car under the carpet? Where did you drill holes? how big? Etc. I just want to make sure I get everything right. Thanks for your help everyone!!!
2nd Mustang
2,488
Southern California
Jul 31, 2004
  • Jul 31, 2004
I've seen many neat installations on this board. My battery was relocated by the previous owner. It sits in a battery tray bolted to the passenger side by the rear fender. The ground lead goes to the frame through the floor board. All cables go through rubber grommets through the floor and front fender to the solenoid. The solenoid was moved to the firewall in the engine compartment. It is a nice job by the PO. I've seen other installations where the solenoid was moved to the trunk, which is really nice too, but I tend to carry things in my trunk, so I didn't want to do that. Oh, the positive cable is run along side of the frame rails and held in place with clamps screwed onto the frame.
Billgear
500
Concord, CA
Jul 31, 2004
  • Jul 31, 2004
I hate to cross post to other forums, but i don't want to write my reply again... So, see this post
stephen4785
321
Fort Worth Texas
Jul 31, 2004
  • Jul 31, 2004
If you move your solenoid to your trunk itll make it a little harder to hotwire.Our cars are easy enough to steal as it is.
xoxbxfx
3,959
Southlake, TX
Aug 1, 2004
  • Aug 1, 2004
Move it to under the dash and see how hard that is.... people wont know where it is.
J
Jaymes
11
  • Aug 1, 2004
what guage wire should I use in order to move the solenoid to the trunk? I know standard will be to small for that distance.
xoxbxfx
3,959
Southlake, TX
Aug 1, 2004
  • Aug 1, 2004
if you move the solenoid to the trunk, I would just use the hot side wire that is included in teh kit and use it for the starter wire. I personally would use 0 or 00 gauge wire for any thing that uses taht much power and is that long.
R
Roddster
Lansing, the one in Illinois
Aug 1, 2004
  • Aug 1, 2004
warning
If you plan to ever run your car at an NHRA track, you will need to install a battery power shut off that also kills the ignition. If that isn't bad enough, you will aqlso need to install a metal (20 GA. minimum) panel between the trunk and interior.
J
Jaymes
11
  • Aug 4, 2004
Let me get this straight in my mind, I should use the Postive battery cable that came with the kit to run from the solenoid to the engine compartment?? It was recommended that I use 0 or 00 guage to run from the solenoid in the trunk to the engine. Isnt that the size of the positive cable?
bud4660
459
Mesquite, Tx
Aug 5, 2004
#10
  • Aug 5, 2004
  • #10
I ran mine over the pass side wheel well and down through the door jam (under the scuff plate) up behind the front kick pan and out the firewall. I also used either 1 ga or 2 ga batter cable. I dont remember off hand. I want to say the 1 ga.
J
Jaymes
11
#11
  • Aug 5, 2004
  • #11
I am giong to relocate the battery and the solenoid into the trunk. WHat guage wire should I run from the solenoid (not the battery) into the trunk. WHat kind of wire? I seem to be getting mixed messages. SOme people think I am talking about the battery cable. I will not be running the battery cable from the trunk to engine. Just the wire from the solenoid
bud4660
459
Mesquite, Tx
Aug 5, 2004
#12
  • Aug 5, 2004
  • #12
I would say nothing less than 12 ga, might even use 10 ga depending on how many feet you need to run it. If you move the solenoid to the trunk dont you still need to take the starter cable from the other side of it to the starter. And I think that the cable to the starter needs to be shorter than the cable to the battery-solenoid does. But thats just my thinking. This is the third car I have had the battery in the trunk. Never had any problems.
J
Jaymes
11
#13
  • Aug 5, 2004
  • #13
Thanks for the response bud 4660
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Engine Crankcase vent tube “relocation”?
  • Mcmahst
  • Nov 20, 2025
Fox 5.0 Mustang Tech Dec 20, 2025
manicmechanic007
Fox Jump/start - Charging
  • PonyGTrider
  • Oct 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
PonyGTrider
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
