  • 2010 - 2014 Specific Tech
Bbk Cat Delete Pipe???
  • Thread starter Thread starter 2012 Boss 302
  • Start date Start date Jul 15, 2012
2012 Boss 302
  • Jul 15, 2012
I have done the searches here and on other sites and cannot find a lot of info on these.
I understand the complete off road pipe may be the way to go because of the larger and more consistant pipe diameter. I want to keep my Boss side pipes and I cannot justify $800-900 for a Boss specific pipe (see link http://www.mrt-direct.com/93o901.html ).
bam2012
11
  • Jul 15, 2012
I have them with after cat bbk x pipe. The fit was ok, I needed to file some on the cat delete to get a leak free connection. It was about 30-45 mins of filing and test fitting, but I have zero leaks. The bolts from stock header to cat are a bitch to remove, but on jack stands with an extra set of hands we did the full install in less than 2 1/2 hrs.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Jul 15, 2012
  • Jul 15, 2012
The BBK pipes have been known to leak at the junction to the stock H pipe, especially on the drivers side. Just read the reviews on other forums or on americanmuscle.com where most complain about fitment and leak issues only fixable by welding (wtf is the point of buying a bolt on part if it needs to be welded????)
I have never seen anyone have any issues with the Jegs delete pipes. The Jegs pipes are also available in stainless steel, if that's important to you. http://www.jegs.com/i/JEGS-Performance-Products/555/30580/10002/-1 Check them out.
2012 Boss 302
  • Jul 15, 2012
Very informative Mr. Poop , thanks....
Reactions: stang8urimport
chris28912
133
Jul 17, 2012
  • Jul 17, 2012
Defeats the purpose of being a bolt on if its welded. Call it a weld on : P
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
6K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
