I finally got my car running
with a J4J1.CCF and a bunch of tweaks. Man it pulls so hard now, it's crazyness :SNSign: First time I got on it, I was halfway through 3rd quicker than I used to get through 2nd. There's no time to look at the tach anymore so I keep hitting the 6k rev limit I setup, I might need to bump it up some. But it idles steady and lopey with the 110° LSA, it sounds mean!
Anyway, on my list of things to finish on the car is fixing the damn EGR connection at the header. I installed the tube that came with the headers and tightened it as much as I could to the bung. Well the pipe is still lose in there and won't seal against the bung istelf since it's not physically being pressed against it
It sounds like a steam engine when I'm idling around the parking lot. My gasket kit came with some small O-ring seals that look like they are supposed to go there. Has anyone else had the same problem with these headers? Should I cut the stock EGR tube down and see if it seals the connection or what? Thanks!
