No, any ligitimate manufacturer understands how to rate the cfm of a fan and the link that I posted even shows how to calculate it, it's not exactly rocket science. If you just want to plug the numbers in, here's a better link
http://www.dccontrol.com/fcfm.htm The ratings generated are for a variable pitch blade design, 50% blade coverage, and assumes a 10% loss from nonuniform flow.
The one you're referring to isn't a high power motor with a low blade pitch, it's a low powered motor with about three times the correct pitch for a 9.8A motor. The aircraft noise that you're referring to is from a poor blade design, not airflow capability, but even if the blade was sized properly, with the motor size and blade diameter of that fan, the highest theoretical airflow that could be attained is a little over 2000 cfm. As I stated before, the airflow for that fan is realistically about 1500 cfm.
