  • 1994 - 1995 Specific Tech
belt came off
  • Thread starter Thread starter 95mustang_gt
  • Start date Start date Jul 24, 2005
9
95mustang_gt
364
Wisconsin
Jul 24, 2005
  • Jul 24, 2005
Well i was trying to take the alt. out and some how the belt comes off all the pulleys.Is the belt easy to put back on?How many bolts are they to hold the alt?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 24, 2005
  • Jul 24, 2005
theres 3 bolts you have to take out to get the alt out, pretty easy.
2 in the front and 1 that holds a bracket in the back.
you also have to unplug the wiring that goes to it and undo the nut that holds the main power wire on.
the belt should go back on pretty easy, just follow the belt routing on the radiator cover but dont go under the idler pully (will give you enough slack to get the belt on everything without falling off) then after its in place just push it down under it and your done
R
rockin_rick
968
Jul 24, 2005
  • Jul 24, 2005
The alt has 2 mounting bolts, the small one torques to 15-21 lb-ft, while the larger bottom one is 30-41 lb-ft.
Mine doesn't have a third bolt holding a bracket Had it out just last week....
Rick
urban96
3,464
Syracuse, NY
Jul 24, 2005
  • Jul 24, 2005
i think it was just some small little bracket that holds up some of the smog or vaccume lines, dont remember now
R
rockin_rick
968
Jul 24, 2005
  • Jul 24, 2005
maybe, I don't have that crap....
HISSIN50
34
129
Jul 25, 2005
  • Jul 25, 2005
It is worth mentioning - DISCONNECT the battery before doing this task.
Good luck.
R
rockin_rick
968
Jul 25, 2005
  • Jul 25, 2005
Yep, that wire on the back is hot all the time.
Power cable nut = 10mm
Small bolt = 13mm
Large bolt = 15mm
Rick
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Cleaning up Aluminum
  • limp
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2026
KRUISR
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
SOLD AEM Failsafe Wideband Boost Gauge for sale
  • TTSaleen
  • Feb 22, 2026
  • Other Classifieds
Other Classifieds Mar 9, 2026
TTSaleen
