What is the belt length needed on a 5.0 with the FRPP A/C delete kit, which is the kit that removes the A/C pump and relocates the power steering pump. Thanks in advance.
on my set up with no a/c and no thomactor pump, with under drive pulleys i used a 695k6. i also had to remove the tensioner and drill a new hole to reposition the tensioner. my belt rubbed together. it looks fine at first but when the belt stretches it will rub. or you could spend like $60 through summit and get a new alternator bracket kit with a adjustable tie rod.
Well Ford just tells me to get a non-A/C belt. problem is that there is no belt listed for a non- A/C 5.0 And since i also have the votech on there a normal tensioner rod on the alternator is not going to work haha. So i'm looking for the length of belt without the A/C pump on the motor, everything else is there.
