Belt Length
JD1964
there is enough sticking out to grab on to
3,605
1,611
194
Maryland
I'm going to remove the smog pump eventually. I'll be keeping the factory AC (still blows nice and cold). I've been reading and understand I'll need an 84.5" belt after the smog pump is removed.
To expand, under-drive pulleys might be in the mix too. Will that affect the belt length? I see the vendors offering them and they don't mention the need for a different belt. I figure that since the crank pulley is smaller, and the alt and water pump pulleys are larger, the belt length from a typical pulley swap basically stays the same?
Is this correct?
The best thing you can d is measure it with a string. Run it around the pulleys like you would the belt then measure it.Take tha measurement to the parts store of your choice and voila you will have the correct belt length.
Leave your stock pulleys alone, in my opinion. I was never a fan of underdrive pulleys. Something about spinning all of your accessories slower just doesn't sit well with me...
I have used U/D pulleys on several cars and they work fine. The key is you must have a 130 amp 3G alternator and your cooling system needs to be in good working order. Also, do not use a race crank pulley. You should use the same length belt but I would check with the pulley vendor. Stay away from the cheap off brand sets as their quality and tolerances are questionable.
:sigh: No....the March Power & Amp series pulley set has a smaller, overdrive alternator pulley (1 11/16").
Correct. I am running that on my car- recommended for automatics- as the stock alt pulley (2 3/8'?) will not spin the alt fast enough to maintain a proper charge. Just go to the vendor's website and it should tell you the appropriate belt. I needed a slightly shorter belt do to the smog pump delete pulley.
My conclusion is such.
The 84.5 worked with the smog pump delete. It also worked when the UD pulleys were installed but the tensioner was sprung all the way down (completely vertical).
I went a got a 83.5 and it fits perfect with smog pump delete and UD pulley combined.
