Belt question
Are you deleting the smog pump as well? or just the a/c. You wont be able to get a straight answer. When I did my a/c and smog delete, i saw people using 70.5", 71.5", 73", I had no idea what to get. Your going to have to test it out for yourself, get an idea of what size you need without the a/c and, if you have some extra money, buy a few belts and return the ones that dont fit. You could try a piece of string to measure but idk if thatll be too accurate.
Your best bet will be like I said, get an idea of the size and buy a few, or have an extra ride and make a few trips. I ended up need a 74.5 and had to make 3 trips to the part store.
Oh and incase you dont know youll need the bracket that moves the power steering pump up.
Heres a pic of mine, I painted my pump black cause the yellow is hideous my smog is gone aswell.
I got rid of the smog and a/c stuff. I did get the power pump relocation bracket. I thought I had a belt for it but I found out that i routed it wrong and it would eventualy stretch a little and rub right above the water pump. So now i need to go get another one. Really anoying because i probobly cant return this one because i already used it.
