Engine Belt Routing
bertman
55
Portsmouth Va
Can anybody tell me what belt i need. I have A/C eliminater kit and it moved the PS pump up to where the A/C was. Summit told me what belt to use, but its not right. I have no smog pump either. The belt is 84.5 inches and its to long
The best method I've ever used -
go to the parts store and get a cheap 1" or so wide ratcheting tie down. Use it to route in the belt config you would like and measure length. Reinstall, but ratchet it completely down (max the tensioner). choose a belt length that is as close to the median of those two numbers.
75 fit but not tight. Got a 74.5 going to try it tonight. Stock pulleys. Love those pics mikestang63
If the 74.5 is too tight, try a larger aftermarket pulley on the idler and tensioner. Often times the aftermarket stock replacement ones from the parts store are a little bit bigger or smaller and can mess up what belt sizes should be.
Check the appoximate length required using a piece of string along one of the routings shown in the diagram below:
So I've been having a belt issue. My setup stretches my belt, and I need a new one every ~3 months. Mine is set up like the smog pump bypass, but the AC is deleted, the powersteering was not relocated, and there is a tensioner bar, no belt tensioner.
So it is alternator to PS, to crank and water pump....It was this way when I bought the car, I just replaced the brackets it had, since they were old and broken. It has the MARCH A/C delete and MARCH alternator bracket with tensioner bar.
How tight are you cranking down on the tensioner? You want some deflection of the belt.
The automatic tensioner does compensate for belt stretch. It's why I'm very hesitant to convert to a system like what March uses that locks in a specific tension and requires some adjustment.
One of my daily drivers has such a setup and I've had to readjust tension a few times to compensate for stretch..which does happen.
On my Mustang, i've marked on the tensioner using the indicator arrow where a belt "sat" when i put it on fresh. A year or two later you can see it's moved quite a bit from that spot.
Here are the pictures of my belt setup...
The tensioner bar is underneath the coolant line going to the thermostat.
As to refresh, my belt is stretching every couple weeks and needs to be tightened. I just tightened it yesterday to get rid of a start up squeal. The tensioner bar doesn't have much left in term of length, so after another adjustment or two I'll have to replace a perfectly good 25 dollar belt....
