Can you grind the stop on the tensioner back so you can pull it back further? Or is it just lack of room stopping you?
Not hitting the stop. Can't get the tensioner that far because of lack of room/leverage. The only thing I can get in there at the moment is a flat-head screwdriver, since the mounting bracket is in the way, and that lets me get it back just far enough to tease me.
It is almost annoying enough to make me say forget it and just go buy a roots blower. :LOL: it would suddenly become the most expensive belt replacement ever.
Seriously though. My Roommate is going to help me tomorrow, between the two of us we may be able to get enough leverage/muscle to get the belt on.
Vortech, by the way, was no help on the phone. They just read back the instructions which make no sense. "Use locking pliers to release the tension on the belt"... WTF does that mean?! ... I actually thought about using them to grip the tensioner to the water pump pulley :LOL:... but I didn't want to damage either the pump puller or the tensioner.
EDIT:
OK. Between my roommate and I we got it on. We used my 1/2" drive breaker socket wrench with a 3/8" converter and a 2" extension to get into the tensioner. We pulled the tensioner back out of the way of everything with one bolt holding the S/C for pivoting. Once the belt was in place, I put the rest of the bolts into the mounting bracket. We used a Flat-Head screwdriver to keep the tension off while we pulled the extension and ratchet out. Then we slid out the Flat-head screwdriver and let the tensioner take on the tension. The belt isn't stupid tight, has some bounce in it, and everything is now running.
There is a small knocking sound coming from the vicinity of the tensioner pulley and S/C idler pulley. I'm thinking that in my gusto to try and pull back the tensioner, I may have damaged the tensioner pulley. The knock speeds up and slows down with the engine. I have re-tightened all the bolts on the S/C mounting bracket and am going to live with the knock for the time being, at least it is drive able.
Thanks guys for the help. I need to come up with a mod to do the next time I have to take this thing off so at least I feel like I'm getting something for all my pain and suffering. Maybe I'll go down another size pulley on the S/C...
