  • SN95 4.6L Mustang Tech
Benefit from Timing Advance?
  • Thread starter Thread starter propellerhead
  • Start date Start date Jul 26, 2004
propellerhead
1,541
"but what's with the but shots?"
Jul 26, 2004
  • Jul 26, 2004
My 04 GT pings under heavy load above 70 mph in hot weather with the a/c running. I resort to using the midgrade fuel (89 octane) instead of the regular unleaded (87 octane).
Since I'm forced to pay for the 89 octane, would I be able to advance the timing a little using a timing adjuster? Enough to benefit from it?
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Jul 26, 2004
  • Jul 26, 2004
The more you advance the timing the more succeptable to pinging. Mine is set to 15 degrees (via EEC reflash) and I have no trouble with 93 octane. The timing advance seems to give a little more low-end grunt.
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Jul 26, 2004
  • Jul 26, 2004
mrvax, how much was the eec reflash?
propellerhead
1,541
Jul 26, 2004
  • Jul 26, 2004
Does everyone with a timing adjuster run 91+ octane?
2013 Geee T
805
Oak Park, CA
Jul 26, 2004
  • Jul 26, 2004
It could be the good ole K&N oil on the MAF wire problem too. You may want to clean it.
03gtmustang
923
Northern Va
Jul 26, 2004
  • Jul 26, 2004
With a timing adjustor you have to run AT LEAST 91 octane, 93 is even better. If you dont then you will get pinging. Ford recomends NOT cleaning the MAF sensor.
propellerhead
1,541
Jul 26, 2004
  • Jul 26, 2004
03gtmustang said:
With a timing adjustor you have to run AT LEAST 91 octane...<snip>
I have to run 91 octane? Can't you adjust it just far enough to get the most advance without pinging with 89 octane?
J
JeepXJ
Austin, Texas
Jul 26, 2004
  • Jul 26, 2004
timing
Just run the 91/93 and eliminate the pinging all together. The car will run better. If your gonna run a timing adjuster and bump the timing up past stock, your gonna have to run 91/93.
2k2fourpointsix
210
Quincy, MA
Jul 26, 2004
  • Jul 26, 2004
It's better to be safe and run the 93, You don't want the motor to knock under WOT and you might not hear it. If you want to mod you car, you can't pinch pennies when it come to gas.
mrvax
Jul 26, 2004
#10
  • Jul 26, 2004
  • #10
I told Tim that I wouldn't quote the exact price on SN but it is cheaper than a chip or a timing adjuster plus a few other things. For example, you can adjust for gears or turn off your post-cats sensor, tweak the A/F and have the computer re-learn new mods and maintain the "good" settings.
PM CobraKiller. Tell him mrvax sent ya.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
M
Progress Thread Monkeybutt2000's 89 vert build thread- 408w build in progress
  • Monkeybutt2000
  • Apr 4, 2020
  • 20 21 22
72K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2026
2Blue2
New Member: 1978 M II Mach I
  • 351MooseStang
  • May 24, 2019
3K
1974 - 1978 Mustang II Talk & Tech May 30, 2019
351MooseStang
