whats the benefit of having the engine run cooler? i always thought engines didnt run as efficiantly when cooler than normal
RysRed96GT said:whats the benefit of having the engine run cooler? i always thought engines didnt run as efficiantly when cooler than normal![]()
Note, you can turn the engine fan on by turning the air knob full CW
Rio96 said:I dissagree. Detonation is a function of spark timing,
a/f, charge temp, VE,, detonation should be controlled
by the ecm.
Rio96 said:How do you know this?, IMO, the issue is whether the
piston rings are properly lubricated.
Rio96 said:With a car that never gets fully warmed-up, maybe,
with the car warmed up, and in closed loop, don't think so.
redlined50 said:nice find but getting a 180 degree thermostat doesn't mean the the metals are at 180* I am sure they are much higher than that.
