benefits of an H pipe?
GT89Mustang said:
Nothing, since the factory pipe in an h-pipe, adding an aftermarket one w/o cats or with highflow cats can free up some hp, plus give the car a better sound.
GT89's right, all factory 87-93 V8 cars had an H-pipe.
As far as aftermarket ones go, they are almost all 2.5" compared to the 2.25" stocker. Putting an offroad h-pipe (no cats) in place of a stock catted pipe will make the car quite a bit louder at high RPM's too.
Jeff
The stocker also seems to weigh a decent bit compared to the O/R's. Not a biggie for racin' (speakin only of 'weight savings'), but it is for wrenchin.
The Factory added an "H" pipe to the exhaust starting in 1986? with the introduction of the SFI systems. The function of any crossover pipe is to help equalize exhaust pressure between both cylinder banks. The equalization helps the exhaust gases out of the header area.
The factory H-pipe had 4 cats. Each pair (front and rear) took care of different noxious emmsions to help meet all of the NHTSA (FMVSS) requirements. They were also pretty restrictive. Changing to a newer H-pipe with only 2 catalytic converters (1 converter that does the job of 2 older ones) will probalby bring you some power.
An O/R pipe will really let the gases flow, but your car will be smelling if it sits for too long at a stop light. (trust me)
differences between X-pipe and H-pipe really are just in the sound and "supposedly" where the power band hits. An X gives off a higher pitch sound and a H gives off a lower tone.
All of this probably isn't helpful, but it was fun to type out.
Interesting, I never knew each pair of cats took care of different emissions. Well, you learn something new every day!
And since I learned my new thing for today first thing in the morning, I guess I get to sit around, be lazy, and do nothing all day!!! :D
Jeff
Glad to see this topic come up. I have been debating wheather to get an o/r pipe or not. As you can see my Stang is lightly modded. Car is pretty quick with just the few things I have.
It sounds like it will be worth the $$$$ to install one. Since our state does not have inspection anymore, the only way to get in trouble for it is for someone to look under car. Couple questions
1) I am running Dumps now with Flowmasters. Sounds pretty loud now. Will it make annoying loud now. If so I could always install the tailpipes back on it.
2) I saw a post about the fumes. Wont the fumes be coming out of the back of the car with the tailpipes back on?? Or is it still gonna be bad??
3) Will I notice a difference in power by adding one. Im consistantly running between 9.6--9.3 in the 1/8th mile. Will that change any?
4) Should I just get one with hi-flow cats for fume and ozone issue. I think there a pretty big price difference there though.
RUNINAGT said:
1) I am running Dumps now with Flowmasters. Sounds pretty loud not. Will it make annoying loud now. If so I could always install the tailpipes back on it.
O/R pipe + dumps = annoying after 2 weeks IMO
O/R pipe + flows & tails = perfect sounding Mustang
In my case, it was bad enough that I wanted to switch to a catted mid pipe. But this too will depend on where you live. I live in a bigger city so stop & go traffic was very common so the fumes bothered me a great deal. But if you live in a rual area, the fumes would be less noticable because you don't spend so much time sitting still..
Oh and even with tails (on my car) the fumes were no fun
Switching from stock to any aftermarket pipe will yeild some performance improvement here. I can' speak for track times... I never raced a before and after to tell you.
If it were my car, I would go with the catted pipes simply because of my driving habbits. There is some performance to be gained here, but make your decision based on location and driving habbits more than ultimate power numbers.
With tailpipes, I never thought the fumes with an offroad h-pipe were much of an issue. It's no worse than an old car that didn't come with cats.
My friends always commented on how my exhaust smelled like an old muscle car. :rolleyes:
Offroad H + dumps is not good, too damn loud inside the car. I think it would get old before 2 weeks.
That's just my opinion. I know some people are bothered by hydrocarbon fumes more than other people.
Jeff
The noise will get annoying very soon, due to winter getting close and that will make me drive with the windows up. BURRRRRRRRRRR. Sounds good with the windows down. When thier up though you cant hear yourself think. So I have been considering the tailpipes anyway. They sound like there easy to install. With mine having factory headers, if I get different headers will I need a different H-pipe. For fitment wise.
Nope. as long as you get a mid pipe made for shorty headers, it will work with the stock headers, or aftermarket shorties. If you get long tube headers down the road, then you will need a mid pipe made for long tubes.
Another thing to keep in mind if your going to a "high flow" catted x or h pipe the cats will most likly not get you threw emisions. If they do then most likly they will fail ya in the year or so after. So save your stocker pipe if ya gotta do the ole sniffer test. peace
john:p
Some places can give you a hard time at the sniffer test... JT has a great thread about that though and was able to get a passing grade with newer cats.
I'll see if I can link to it.
Yep, Steve's right. I just got done doing this again. I have nice three-way cats but because I have fewer cats than came in OEM form (what would be the point of two 3-way cats in series. :bang: ), I get hosed with.
The process after that will depend upon local regulations.
Good luck.
