Just like the thread title reads... what are the benefits of synthetic oil over conventional oils? Durability, Protection? What are some experiences with both...?
Thanks!
Thanks!
True, but there's another reason. Unseasoned parts and blocks have no oil content, and metals actually are porous, so they do soak up a hefty amount of oil in the first few thousand miles. Synthetic doesn't work the same, and is more likely to coat than soak in. It's a good idea to let a new engine season for four to ten thousand miles (depending on if it's a rebuild with machining and new parts, or a completely virgin block etc) before switching to synthetic.90mustangGT said:Synthetic oil is smaller on the molecular level, so even if it generally flows the same, it will get into the little places regular oil has a hard time to get into. This can also make larger leaks out of smaller leaks. They synthetic is more slippery, that is why your not suposed to use in when breaking in an engine.
I have 140,000 miles on a Jeep 4.0 engine, 135,000 with Castrol Syntec oil. No foaming ever (granted the Jeep hardly sees above 5000rpm). I used to own a '70 Mustang with a 351c with 4V heads. I used Castrol Syntec in it as well and it did see high rpms (the only way to get air through those huge ports) and never saw any foaming.Mhypertext said:I don't run it because it FOAMS at high RPMs
and you cant switch to it you have to run it in a new motor not one that has been runnning on conventional oil
