  • SN95 4.6L Mustang Tech
Bent the shift fork?
  • Thread starter Thread starter ThePhotoGuy
  • Start date Start date Nov 25, 2007
T
ThePhotoGuy
  • Nov 25, 2007
Just got a 97 cobra with some work done on it from a buddy of mine. Use to drive a 04 S80 Volvo, little different and all the excitement of having the car caused the problem lol...
Wanted to make a little smoke out of the tires and everything was going great, grand and wonderful. Havent driven a fast car in a while, banged it into 2nd for a second then let off it. Then problems.
When the car is in neutral, it's still "in gear" and by that I mean I can give it gas and it will move. When the car is at a stop, i can put it in any gear, but when I try and drive, it will go in only 1st and 2nd. Heres where the real fun begins. 1st gear is fine. 2nd gear not so much. When I go to shift to 2nd it goes into gear waaaay easy, and it feels like it's still in 1st. Also, it will not go in any other gear while driving.
I'm thinking I bent the shift fork.... suggestions/comments and if that sounds right, anyone know where a tutorial is posted it's been a while since I've turned a wrench.
T
ThePhotoGuy
  • Nov 26, 2007
bump?
Matt's 03 GT
Orange County
Nov 26, 2007
  • Nov 26, 2007
Could it be the Clutch? It sounds like it is not disengaging???
T
ThePhotoGuy
  • Nov 26, 2007
well there was alot of play in the clutch pedal, the motors been rebuilt and it has a cable clutch. Tightened the play in it and it still does it. It's a stage 3 clutch and havent smoked it so i was assuming it was the shift fork so....
Tim2002GT
635
Tulsa, Oklahoma
Nov 27, 2007
  • Nov 27, 2007
Sounds to me like a bent/broken shift fork. Possibly the roll pin that holds the fork on the rail could've backed out.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
