Best All In One Complete Gt40 Gasket Set
I'm swapping heads and the intake. So I would need exhaust gaskets, intake gaskets, head gaskets, and valve cover gaskets at a minimum. The other stuff is really just extras.
But I havn't found any there gasket set that included just what I need...
Do yourself a favor and get the reusable valve cover gaskets. The cork in that kit is bull****
Good point. So really the best way to do it is buy the head gaskets, intake gaskets, and valve cover gaskets all separately.
That kind of sucks...
ok you want the blue rubber VC gaskets with the steel inserts
for Head gaskets 9333pt1
Intake gaskets Felpro 1250S3- steel inserts . do not use the cork end rails. either use the rubber ones or what I do is a thick bead of Right Stuff
You'll need the upper to lower intake gasket for a GT40, explorer, Cobra
Exhaust- think its 1415?
Then get Felpro timing cover, thermostat gasket, Throttle body, EGR
If you are replacing your top end then I highly recommend you also replace
  • thermostat
  • timing chain and gears
  • harmonic balancer with a good pioneer, romac, or other SFI
  • water pump
  • Timing cover seal
  • head bolts- get ARP bolts or studs
  • intake, exhaust, timing cover, water pump bolts- ARP
let me know if you need specific part #'s on what I have used
