mightymidget said:For instance would I be able to start with stock short block
and cam for SD with steeda 1.7 cobra rockers
Then install GT 40 heads /intake set up.
and have postive results with my SD set up
brian15 said:ok i would say the best all around speed density cam is the crower 15511 .
with that out of the way i dont think you should cam your car yet yes its cheaper than heads and stuff but you wint see the real gains out of it till the rest of your engine is oppened up .
im running performer rpm heads and matching intake with a stock cam and 1.7 rockers and am 12.50's and faster .
granted a cam would help and i might go that route soon the stock cam offers a ton of performance .
in my opinion mass air isnt worth it unless your going with a super charger or some crazy combo of parts ..
87stangdiddle said:.....sooner or later youre gonna need it anyway when u do heads and intake....
99redgt said:How does the speed density respond to the spray say heads, intake, 1.7 rockers and a 150 shot?
tjm73 said:Don't fool yourself, you either need to change to Mass-Air or get a tunable SD engine control system like the Western Motorsports SDS.
At WOT spray and heads don't really matter much. The computer doesn't use the SD A/f charts or the MAF calculations. It uses dedicated WOT settings.
You're real concern is part throttle driving. That's where and why you need the MAF conversion or tunable SD system.
