Best differential for the street?
  • Thread starter Thread starter steel1212
  • Start date Start date Oct 21, 2004
steel1212
1,180
Frankfort, Ky
Oct 21, 2004
  • Oct 21, 2004
What is the best limited slip/posi for the strip? I don't want something thats going to be making a lot of noise going around the corners but I want to hook up also...I'll be putting cal-tracs on there as well as subframe connectors. I know everybody has their opinions but give me the reason why you picked what you did and why:
PRICE
NOISE
QUALITY
Also anybody tried the newer one that doesn't use clutchs?
J
jaredgoodwin
62
  • Oct 21, 2004
Powertrax No-Slip
I bought a powertrax no slip and I really like it. The only noise it makes (after the 50 mile break in) is when I am turning hard in a parking lot at 3mph or less. And once you have it for a while you get used to it and you can even make that very minimal. As far as on the road, this thing hooks up great. It is supposed to last longer than the clutch style diffs. I would highly recommend it. Get ready to go sideways....
bmcelhinn
64
  • Oct 21, 2004
DPI Black gold street differential. Works like a posi when you accelerate, but rolls freely through turns like an open differential. If one wheel brakes loose it puts power where you have traction. It can take up to 750hp/tq reliably, doesn't make any noise, doesn't use springs or clutches like a limited slip so it hits much harder, etc etc.
eric n
875
Bakersfield, CA
Oct 21, 2004
  • Oct 21, 2004
I have auburn pro unit and love it. It was suggested to me by PEARSON'S AUTO, a highly recommended local guy. Love it and the launch is far superior. I also went from 3:00's to 3:70's. Again FAR SUPERIOR
steel1212
1,180
Frankfort, Ky
Oct 21, 2004
  • Oct 21, 2004
See this is the problem I run into. There is 3 posts and 3 diffrent ones. Are they all that good or should I be asking which ones to stay away from?
66P51GT
721
Cerritos, CA
Oct 21, 2004
  • Oct 21, 2004
Of the three listed, there are mechanical and clutch style differentials; each are best suited on the type of driving you are doing. Generally speaking, mechanical are best suited for 1/4 mi. These include Powertrax, Detroit Locker, and others. Clutch styles are best suited for Autocross and Open Track. These include Ford traction-loc, Auburns, and other limited slip type differentials.
Of the three listed I'd choose the Auburn. Griggs racing uses Auburn's in all of their track beasts and are proven performers under extreme conditions.
I personally chose a 4-Spider Traction-Loc for my 8". If I ever have the need for a 9", I'd choose the Auburn. If you plan on using the 8", your choices will be fewer.
Cost wise, they are all relatively the same and are in the $350 - $500 range.
bmcelhinn
64
  • Oct 21, 2004
The DPI is mechanical but is better for drag/street/autocross than all of those. It works like all of them in the same package. It basically changes it's operation because it reacts to driving conditions. Top road racers and circle track drivers use them and they are completely gear driven. They are also good like a Posi or locker because they bind on their own and work like a posi under acceleration until one wheel brakes traction and then it acts like an LSD and puts power to the wheel with traction.
None of the other differentials are even worthy of comparison, the only thing that the Black Gold lacks is price because it costs $650 But none of those other differentials can hold a candle to it in any way shape or form. It drives like a whole new car upgrading from an Auburn or Posi to a Black gold. They are better around town, and better for performance driving hands down.
66P51GT
721
Cerritos, CA
Oct 21, 2004
  • Oct 21, 2004
steel1212
What size rear end are you using?
P
Paul619
83
  • Oct 21, 2004
I have that one too with 3:25 gears.I love it a lil bit noisy around the turns at slow speed definitly good though
eric n
875
Bakersfield, CA
Oct 21, 2004
#10
  • Oct 21, 2004
  • #10
I guess I got lucky, I have no audible noise around corners. Then again maybe I can't hear it over my noisy arse flowmasters or maybe I never actually slow down. Anyway, without a lot of knowlege I can say an auburn in a 9" rear (mine is a 28 spline ) running 280 hp 292# at the rear wheels, is much good fun.
2bav8
2,511
Mesa, AZ
Oct 21, 2004
#11
  • Oct 21, 2004
  • #11
Just a heads up on your setup and not wanting noise, my Cal-Tracs make a heck of a lot more noise than my Locker does.
steel1212
1,180
Frankfort, Ky
Oct 22, 2004
#12
  • Oct 22, 2004
  • #12
I have an 8 inch rear with stock gears and I'm trying to decide on that one to if I want to get a currie 9" or just build my 8. I'm thinking my engine will be around 360ish hp with afr 165s and I'm pretty sure the 8 can handle that especially if I upgrade the diff and gears. Now later on when I get a stroker.....
As for makeing noise I don't want something thats going to sound like my rearend is trying to ratchet itself out from under my car. I mean I have flow master 40s and they aren't exactly the quietest.
2bav8 you do make a point I guess when I get my cals they are going to be noisy as well but I didn't figue they would be real loud.
The only posi I'm around on a regular basis is my buddy's 70 chevelle and it still has the factor posi and you can't hear it or the traction bars but then again his exahust ends under the seats right now
66P51GT
721
Cerritos, CA
Oct 22, 2004
#13
  • Oct 22, 2004
  • #13
I will have ~380HP at the crank and chose to use an 8" 4-Spider Traction-Loc with 3:80 gears. Currie sells these but I picked up an entire rebuilt 3rd member with new gears for $550 shipped from fast500xl1@aol.com. He also sells on ebay. His ID is fast500xl1.
If I end up doing the Summit series next spring (assuming the car is done by then!!!), I will upgrade to Currie's new 8" aluminum pinion support. It is only $100 and would not be too expensive to install. It houses a larger/stronger bearing and will shave a few pounds off the RR as well.
steel1212
1,180
Frankfort, Ky
Oct 22, 2004
#14
  • Oct 22, 2004
  • #14
I talked to a guy here in Kentucky that builds rears and he suggested auburn pro, 4pinion that they build or true trax. The true trax he says is quite but is gear driven. Anybody use the true trax? The true trax is around 700 with gears and ready to drop in the other 2 are around 500ish.
bmcelhinn
64
#15
  • Oct 22, 2004
  • #15
True Trax is similar to the DPI black gold.
N
nds03
166
#16
  • Oct 22, 2004
  • #16
I just got an 8 inch with 3:80 from fast500kl1. took out the old center today, putting in new one tomorow
be prepared to wait. he told me it would take 3 weeks, but it took 4
fvike
335
Mosjøen, Norway
Oct 22, 2004
#17
  • Oct 22, 2004
  • #17
So this is a torque-sensing differential ? Like the ones you find in Audi's Quattro system?
66P51GT
721
Cerritos, CA
Oct 22, 2004
#18
  • Oct 22, 2004
  • #18
Please do tell how it works out. Mine has been sitting in the box for several months... waiting to install the rest of the drivetrain.
D
Dragonacc
29
GA
Oct 22, 2004
#19
  • Oct 22, 2004
  • #19
Just reading DPI's website real quick, the Black Gold is a torque sensing differential, not exactly like the Audi system though because I believe their's has an electronic element to it too.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
