  • SN95 4.6L Mustang Tech
Best intake plenum/TB combo?
  • Thread starter Thread starter BurningRubber
  • Start date Start date Apr 13, 2006
  • 3
First Prev 2 of 3 Next Last
edbo
198
Valley, AL
Apr 14, 2006
#21
  • Apr 14, 2006
  • #21
Here's links to the plenum showdowns on the ModularDepot site:
First Test: http://www.modulardepot.com/?show=articlesdet&aid=30
Second Test: http://www.modulardepot.com/?show=articlesdet&aid=38
BurningRubber
1,865
24
58
Apr 14, 2006
#22
  • Apr 14, 2006
  • #22
Well after reading both of those tests and realizing the test car allready had longtubes, x pipe and catback, and it still only made 7 hp it seems like alot of money for something thats not gonna make 7 hp on a stock engine.
Think the money would be better spent on U/D pulleys or exhaust? For 430 bucks for the Accufab plenum and t/b I could buy a UPR X-pipe, two Magnapacks and dumps off ebay, and nab the Steeda U/D pulleys.
Even though it doesnt make as much power, the C&L unit is still appealing... For 120 bucks it is still a few HP, which is hard to beat now a days.
edbo
198
Valley, AL
Apr 14, 2006
#23
  • Apr 14, 2006
  • #23
Get the BBK underdrive pulleys. I got them for my '98 GT for like $130 from Summit Racing and the results were pretty noticeable, even on that ol' pig. Not to mention that they dressed up the engine pretty nice too. That leaves $300 bucks to put on exhaust mods. You'll get a lot better HP/Dollar going that route, unless of course you've already got some gears which is the first mod I always recommend (besides K&N filter). A nice set of 3.73s or 4.10s will really be sweet on that GT.
hotdog71
427
Seattle, Eastside
Apr 14, 2006
#24
  • Apr 14, 2006
  • #24
The only thing the test proved is that a 75mm TB/P make more power then a 70mm set-up !!!!
XtorT'r
381
Minnesota, YAAA
Apr 14, 2006
#25
  • Apr 14, 2006
  • #25
I think it proved that the accufab also flows much more air than the ones tested. great mod if you decide to do F/I in the future. I have not been able to find any flow data on BBK the GMS or the PP plenum so I didn't buy it..
BurningRubber
1,865
24
58
Apr 14, 2006
#26
  • Apr 14, 2006
  • #26
Arent they the piggypack kind though? I was told a few times that it was riskey running a piggyback set of pulleys on a 4.6 due to it causing harmonic vibrations and destroying the inernals of the engine. I was also told that piggybacks on 5.0's are fine since they are more inernally balanced or something.
If they replace the harmonic balancer than its all good is what ive been told.
Is that ass backwards or what?
XtorT'r
381
Minnesota, YAAA
Apr 15, 2006
#27
  • Apr 15, 2006
  • #27
I have heard that the steeda udp set has a harmonic balancer.
And you can get a wads more power with an electric water pump than with udp's.
edbo
198
Valley, AL
Apr 19, 2006
#28
  • Apr 19, 2006
  • #28
The BBKs are NOT piggyback units. They're aluminum billet units and I never had an issue with them. They also look very nice installed.
With the BBK (and the Steeda), you get 3 pulleys. One for the crankshaft (harmonic balancer), one water pump and one alternator pulley.
It's really your choice as the Steeda's are pretty nice but they are priced considerably higher than the BBK's.
hognutz
1,940
albany, oregon
Apr 19, 2006
#29
  • Apr 19, 2006
  • #29
accufab made the most power before the BBk came out. have not seen the data on the BBk as I already had my accufab.
TB size depends on which plenum you buy. there is no one size fits all. the c&l preformed better with the 75mm. the accufab flowed the same with both 70mm or 75mm.
My .02 is look on ebay for something used. it is just a block of aluminum. I got my accufab plenum with bbK TB for $300 to my door and it had been used for dyno run only. was not even dirty.
accufab has more power lower in the band. peak numbers are not as important as average for you car being faster in the end. new they are kind of spendy though.
big T
265
Hawaii, oahu
Apr 19, 2006
#30
  • Apr 19, 2006
  • #30
BurningRubber said:
Ok, I read the tests that Falcon Guy had mentioned. The most HP gained was with the Accufab plenum, and Accufab 70mm TB... Why didnt the 75mm TB make more power? Would it be better to get a 70mm TB instead of the 75MM one..?
BigT... Where did you get that setup from? Thats a very nice price.
I got it about 11/2 years ago after read an article in mm&ff. I cant recall the phone # to his shop, but if u do a search on modulat depot/plenums, it will show up in some of the posts, as well as an article about his setup.
2002GreyGT
481
Raleigh, NC
Apr 20, 2006
#31
  • Apr 20, 2006
  • #31
Professional Products - Any good
I have seen a bunch of these on ebay, and they are about half the price of the Accufab or the BBX setups.
Anyone heard of the company and know anything about them?
Professional Products - POWER. Is the name that is on the parts.
~K
R
RoadconeTuning
458
Upstate, SC
Apr 20, 2006
#32
  • Apr 20, 2006
  • #32
can you use a 75plenum w/ a 70tb?
Dorsai
Connecticut
Apr 20, 2006
#33
  • Apr 20, 2006
  • #33
300-400 dollars for 7 hp ? You guys are kidding right ? Your going to notice a difference of 7 hp ? I would think gears and ud pullies would make a much more noticable difference....
javsvt
27
Westchester County NY
Apr 20, 2006
#34
  • Apr 20, 2006
  • #34
I got the professional products TB & plenum. It is really good quality, I had no problem with the installation with the exception of the cruise cable. But all in all it was easy to install. I thought it was a good buy, you get a few less horse power than the accufab, but only 1 or 2 hp. I think its worth it. I felt a difference in the in acceleration. I dont think its worth spending all that money for a plenum and tb, for only 7-10 hp. I paid $250 for my combo. Im happy!
BennyBlown2v
1,233
Carmel, INdiana
Apr 20, 2006
#35
  • Apr 20, 2006
  • #35
Yep! But where have you seen proof that it offers a few less than an accufab setup? I figure with how close the design in plenums is buying the cheapest one possible then port matching it to the intake manifold and throttle body and polishing it is the best bet - I did it and am happy with the results!
javsvt
27
Apr 20, 2006
#36
  • Apr 20, 2006
  • #36
I have not seen any proof, that is why I think it is a good buy. For the hp you are getting on these combos, I think its not worth spending all that much. Just my .02. If you could find something less than go for it, and let us know. That is how we learn what is a good product. Im just responding to his professional products question.
BennyBlown2v
1,233
Carmel, INdiana
Apr 20, 2006
#37
  • Apr 20, 2006
  • #37
Yeah, sorry, I know lol. I agree with you 100% (I have their 75mm tb), I was just wondering if you had seen anything saying it didn't gain as much, I haven't seen any dyno's of PP plenum/tb's on our cars.
And I did get my setup for less, $170 total shipped to my door. No-name "satin" plenum from ebay for $70, then brand new professional products 75mm tb for 100. Works great!
GDawg
1,469
Nevada
Apr 20, 2006
#38
  • Apr 20, 2006
  • #38
As far as I know, the better known plenums will fit a 70mm TB as well as a 75mm TB.
hotdog71
427
Seattle, Eastside
Apr 20, 2006
#39
  • Apr 20, 2006
  • #39
Remember it's not all about hp the feel comes from the +20 tq you gain with a 75mm TB/P... BBK
BurningRubber
1,865
24
58
Apr 20, 2006
#40
  • Apr 20, 2006
  • #40
Damn... is there really that much of a tourqe gain from the BBK setup? Thats very nice. The Accufab only made 7 ft lb's of tourqe.
Tourqe is more fun than HP, haha.
  • 3
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Fox 89’ GT 331 stroker, Trickflow upper/lower, TF#3 Cam, stuffed with forged goodies.
  • 08GT500
  • Nov 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2025
08GT500
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
Dual Blade TB on a 2v
  • Mad Mod
  • Sep 22, 2020
2K
SN95 4.6L Mustang Tech Sep 13, 2021
Mad Mod
