Ooops... Sorry about that mangsquares98 said:you car uses a different pump then the ones previously mentioned
In an '86-'97....no.flexiclese said:could putting in a pump that is well over the flow needed create problems?
the larger flow number will do just that, flow more fuel if needed. The fuel pressure regulator will keep the pressure at the level it needs to be at.flexiclese said:could putting in a pump that is well over the flow needed create problems?
