Best way to remove floor pan?
So about two weekends ago i started to remove my existing seat platforms to make way for some new custom brackets. As usual, there was more rust than expected and I have decided to pull the floor pan out and replace with a full floor pan. I did this once before with my 68 project car by just taking a hammer and chisel and popping out the spot welds with some occasional help from a grinder.
Any recommendations on how to do it this time around? Is there a more effective way to get the old floor out and weld in the new one? I just want to check to see if there is a better way to do it than I did before. Thanks.
-Edgar
-Edgar
http://forums.stangnet.com/showthread.php?t=619062&highlight=floor+pan+removal
Air chisels are great on the rocker panel, and anything thicker than the floor itself. Pops them off without tearing the metal you want to keep. A spot weld remover for anything else. Just dig a little, then hit it with the air hammer and it pops right off.
