Better choice than E cam
the e cam may be the perfect cam for your set up, and if you go bigger/better you'll be losing power because it doesn't match ur combo like the ecam does, so you really gotta specify your combo
cobra intake, edelbrock performer heads,75mm Pro M,70mm TB, 24lb injectors. BBK equal length shorty's. 3" x pipe into 3" flo pros. 1.7 Rockers in it. and the car currently has the e303. oh and 4:30 gears :D and plus much more.
i want to supercharge this car in the future, but i would like to run a 11.99 just n/a before i do so.
If you plan on running NA for a while then going supercharger, to maximize your performance you are talking about two different cams for each application.
Mac Hmslf said:
should i be going custom? the car runs mid 12's as it stand now. car has never seen a dyno or any tune work. im trying to make this run 11's before i charge it :D
If you want to go custom the I would get a hold of Ed Curits. I don't know if he is still around here. I have been away for quite a while.
