• Community Forums
  • Regional Forums and Event Information
Beware! Comp Cam problems.
  • Thread starter Thread starter bigbadjim
  • Start date Start date Jun 12, 2005
bigbadjim
367
Regina, Sk
Jun 12, 2005
  • Jun 12, 2005
I bought a comp cam Extreme energy camshaft. I installed it in my mustang. Went through the proper break in. I put cam lube on lifters and lobes. 2000rpm for 15-20 minutes. Changed oil after a couple miles... Bla, bla,bla! Anyways after 14 miles I started to have some rocker chatter. I thought my rockers needed adjusting, but instead it was the lifters. They were worn down between 1/8" -1/4" on the bottoms. The part that rides on the cam lobes. Some even had holes right into the lifter. Obviously the cam lobes are worn bad, also the bores in which the lifters move in are scratched badly and the lifters are all toast!
What a crock! I talked to a few different guys this weekend and found 4 other guys that have had the same thing happen with their comp cam. One guy was even on his 3rd cam in 1 year. Why even bother!
Comp cams explanation! "Improper break-in."
Anyone else have this problem?
Green4.6GT
Size Matters
2,910
Regina, Sask, Canada
Jun 13, 2005
  • Jun 13, 2005
i have heard ALOT of bad things about comp cams lately... never will i buy anything from them...
VT
351LX
1,007
Regina, Saskatchewan
Jun 13, 2005
  • Jun 13, 2005
A lot of people are having problems with flat tappet cams as the modern engine oils have a lot less zinc in them than they used to and zinc is important when you are breaking in a cam.General Motors sells an additive called General Motors Engine Oil Supplement or GM EOS that is very popular for breaking in cams as it has a high level of zinc in it.They sell it at the GM dealerships for about $6-7 a can.My last couple of cams have been Crane ones and I haven't had any problems.
bigbadjim
367
Regina, Sk
Jun 13, 2005
  • Jun 13, 2005
Anyone ever ran a Isky camshaft in there engine?
W
WOT
2,817
Regina, Canada
Jun 13, 2005
  • Jun 13, 2005
VT
Ahh, VT and MPH cams are ground by Comp Cams. Using Comp cam blanks.
D
DELUXE MW
105
Melville Saskatchewan Canada
Jun 14, 2005
  • Jun 14, 2005
I have had 3 of their 292 series go flat on me even had one of their cams go flat a year after it ran a whole summer , I installed a crane and had no problem since and in my Mopar I run a Hughes Engines cam and it runs very nice for a Ford I suggest Lunati
bigbadjim
367
Regina, Sk
Jun 14, 2005
  • Jun 14, 2005
Mine was the XE-294H Blaaaaaa!
I've been searching around on different forums about "Comp Cams"
Sounds like they have a lot of issues with their camshafts.
I guess I should have searched around before buying one...
maverick0716
3,924
Chilliwack, BC, Canada
Jun 14, 2005
  • Jun 14, 2005
I'm installing a XE270HR in my motor.....since it's roller and not flat tappet I hope I don't have problems.
R
red82gt
434
Kelowna, B.C Canada
Jun 15, 2005
  • Jun 15, 2005
Comp does seem to be having some issues. They ground my custom cam that I bought through Buddy Rawls, he checks over every camshaft to verify all the timing events before he sends it to the customer and with the first one he got from comp, the exhaust lobe was not closing the exhaust valve at all (it was keeping it open about 0.010" at all times). He sent it back to comp and their regular engineering department said there was nothing wrong with it (apparently they only check valve events down to 0.020" of lift) so he had the race engineering division check it since they are a bit more thorough. They determined the master lobe that they use in production was worn out, who knows how many off the shelf cams they turned out with that same worn out master lobe?
My best advice would be to buy a cam from a custom grinder so they can verify that all's well with the cam before you install it.
351LX
1,007
Jun 15, 2005
#10
  • Jun 15, 2005
  • #10
I found this thread on another site talking about Comp Cams and some of the problems them and other manufacturers are having http://www.4m.net/printthread.php?t=139014 It is pretty informative reading.
bigbadjim
367
Regina, Sk
Jun 15, 2005
#11
  • Jun 15, 2005
  • #11
No multi weight oils period! Use Valvoline Racing oil 40 or 50 wt my preference.
150 # seat max and 400 # open max pressures after the cam has lapped in with the lifters.
prime the oiling system before installing the pushrods in the motor.(Very important because even with assembly lube it will scuff with out doing this)
Don't get any paint over spray in the lifter bores when assembling the eng.(You will not believe how common this is so dont laugh).
The bottom line is,in my honest opinion,the quality of the current lifter bodies avail are not up to par,even with the closest tolerences of a re-machined lifter,I have still seen some fail. The manufacturing process of pulling carbon to the bottom of the bottom is not fool proof.There are some great quality lifters up and coming and I look forward to happier days.
Some good info. Thanks Ian!
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jun 15, 2005
#12
  • Jun 15, 2005
  • #12
kind of sounds like wrong valve-train geometry? What valve springs do you have?
bigbadjim
367
Regina, Sk
Jun 15, 2005
#13
  • Jun 15, 2005
  • #13
I'm running comp dual springs with crane 1.6 roller rockers..
TweekedGT
1,274
Alberta
Jun 18, 2005
#14
  • Jun 18, 2005
  • #14
I'm a VT man myself. VT stroked forged short block on the way!
SPEED FREAK
1,448
Regina, SK.
Jun 18, 2005
#15
  • Jun 18, 2005
  • #15
Serious?????? Sweet! That should wake that pig up!
TweekedGT
1,274
Alberta
Jun 18, 2005
#16
  • Jun 18, 2005
  • #16
I don't know what extra horse it will add but I'm sure it will add some mad torque. I'm thinking long term with this one. I want to make sure the motor is done right before I slap the blower on. 20lb's of boost here I come!
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
  • Community Forums
