  • SN95 4.6L Mustang Tech
Bigger Fuel Pumps
  • Thread starter Thread starter IJUSTWON
  • Start date Start date May 3, 2005
I
IJUSTWON
242
  • May 3, 2005
I have a 2001 Bullitt, looking for a good place to buy a 255lph Fuel Pump and also a set of 24lb Injectors? Where is the best place I can find what i'm looking for?
2kyellowgt
224
Nanuet, NY
May 3, 2005
  • May 3, 2005
I would call Randy at liberty Ford 410-655-2000 ext 5618. I just bought injectors and a focus pump from them.
I noticed in your sig you have 5.1 motor, if you are planning a power adder you will need bigger injectors than 24#. I have a stock block with a 100 shot and I running 30# and a focus pump (good to about 400 hp).
I
IJUSTWON
242
  • May 3, 2005
I am going to stay naturally aspirated, but right now am having a problem, seems like once i reach 5300 rpms my power is gone stops pulling....... should i go with 30lb injectors? and what would be a good fuel pump to go with for my setup as of right now. only mods looking into the future is maybe cams but thats later down the road
I
IJUSTWON
242
  • May 3, 2005
2kyellowgt
224
Nanuet, NY
May 3, 2005
  • May 3, 2005
I dont like having to buy twice so if it was me I would try to get injectors and a pump that are going to be a little more than I think I will need.
You can go with a focus pump which should support about 400 hp but I would definetly get 30 # injectors. You are going to have to get a tune with the 24# so with 30#'s atleast you will have a little extra to work with.
You also said at 5300 your power is gone a good dyno tune might be able to help you with that problem.
Good luck
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
