Black box?
  • Thread starter Thread starter Boostin
  • Start date Start date Jun 9, 2005
Boostin
57
  • Jun 9, 2005
What is the black box on the passanger side of my firewall. it has a knob on the top that you can turn. its on a 90 5.0
is this a brake proportioning adjuster?
ss93cobra
1,422
Wilmington NC
Jun 9, 2005
  • Jun 9, 2005
If you're referring to a part located on the back of the passenger side shock tower vs. the firewall and it has a 2 wire plug in as well as a couple of vacuum lines going to it, that is the e.v.r. ( e.g.r. vacuum regulator)
Held down by 2 bolts as well. The top is supposed to turn too.
Boostin
57
  • Jun 9, 2005
What does it do if i turn it?
ss93cobra
1,422
Wilmington NC
Jun 9, 2005
  • Jun 9, 2005
Absolutely nothing. Its designed to act as a vent and release pressure when necessary, therefore the cap has to be slightly loose. You didn't damage anything if thats what you mean. In fact, the cap can be popped off too if you really want to see what it looks like.
stang22
1,318
Washington, D.C.
Jun 9, 2005
  • Jun 9, 2005
Silly question, but is it connected to the brake lines? If it is, you have an adjustable proportioning valve. You have rear disc brakes?
Tim
ss93cobra
1,422
Wilmington NC
Jun 9, 2005
  • Jun 9, 2005
AH! Good point!
Boostin
57
  • Jun 10, 2005
No i dont have rear disc. i dont think its a brake regulator. but the brake lines do run right under it. but i can exactly see whats going into it cause of my a/c lines
stang22
1,318
Washington, D.C.
Jun 10, 2005
  • Jun 10, 2005
Tell me what number it is in this picture.
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
W
Strange connector near fuse box
  • W4rl0ck
  • Sep 23, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 28, 2026
gkomo
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:17 AM
keel
