  • SN95 4.6L Mustang Tech
black cap on IAC
  • Thread starter Thread starter snidehockey
  • Start date Start date Dec 5, 2007
snidehockey
131
Orlando, Fl
Dec 5, 2007
  • Dec 5, 2007
what is the black cap on the IAC valve w/ the little soft foam kinda filters in it for?
I sprayed the filters w/ intake cleaner cause they were so dirty...as well as the whole IAC Valve.
I also took off the throttle body and cleaned it all out, extended my SRI to a CAI
w/ new filter
cleaned all the electrical plugs (MAF - TPS - IAC - IATS) w/ electrical parts cleaner.
Now my rpms hang like crazy...when I take my foot off the gas and hit the clutch they go up just a hair then gradually fall to about 1800 and stay there for a good 5 seconds before it returns to normal.
What I'm trying to figure out is if those circle filters are clogged or too wet will it not let air escape and thus throw it into plenum causing my rpms to stay up?
blacknblue2002
159
Va Beach, Va
Dec 5, 2007
  • Dec 5, 2007
the black box that you took the filter out of and cleaned is simply a 'noise dampener'...it does something to quiet the intake of the car I believe...there has been talk circulating that you can remove the box and connect a longer hose directly from the IAC to your intake...(not sure what good or bad that could do)...as far as the remainder of your problems...I'm having very similar issues so I can't really help you....hanging rpms are generally related to the IAC....but mine is a little more complicated than yours...I'd say if you never had the problem before, just wait for everything to dry out and then try it again...no need for the little 'donut' trick in the iac (explained in sticky above)
snidehockey
131
Orlando, Fl
Dec 5, 2007
  • Dec 5, 2007
I read that thread about the box as well, however theres a round black cap directly on top of the IAC valve...I just took the filters out that I thought may be clogging it but it made no difference so I know that's not the cause.
DTNODYA
831
  • Dec 5, 2007
How did you remove the black cap? Pull on it??
snidehockey
131
Orlando, Fl
Dec 5, 2007
  • Dec 5, 2007
yeah - it snaps off
RandyStinchcomb
1,159
Randallstown, Md
Dec 6, 2007
  • Dec 6, 2007
that black cap is just a vent and has NO effect on performance......chances are you need a new IAC.........
R.J.
813
Warwick, Rhode Island
Dec 6, 2007
  • Dec 6, 2007
+1 new IAC
  • Gulftown980x
  • Jul 29, 2026
squeak93
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
