Blew something...help!
  • Thread starter Thread starter DTT92LX
  • Start date Start date Jul 21, 2004
DTT92LX
185
Downingtown, PA
Jul 21, 2004
  • Jul 21, 2004
Hey,
Punched it yesterday and must've blown out something but can't figger it out...
Car is running really rough. At idle, in park, warm start, it revs at ~750 for 1 sec, then stumbles for 1 sec and keeps cycling that way. During the "stumble" period, I hear a hissing under the hood. Sounds like under the upper intake but can't really tell from where. Also, exhaust smells REALLY rich.
When driving, it sounds fine, haven't really pushed it to test for power loss.
any ideas guys?
DTT92LX
185
Downingtown, PA
Jul 21, 2004
  • Jul 21, 2004
Was just out listening to the hiss and it is definitely coming from under the upper intake. What is that tube that I can see from the front of the car that goes from the intake around back to head/block/somewhere?
shttygtstang
978
  • Jul 21, 2004
head gasket ????? do a compession test theres not much to go buy
DTT92LX
185
Downingtown, PA
Jul 21, 2004
  • Jul 21, 2004
That was my initial thought but saw on here that you should see bubbles in the radiator on a cold start if head gasket. Don't know how reliable that test is though...
Anyone know what that tube is?
J
Js5ohLX
287
Ohio
Jul 21, 2004
  • Jul 21, 2004
Sounds to me like a vacuum line fell off or cracked.
Q
Quick5pnt0
1,208
north eastern PA
Jul 21, 2004
  • Jul 21, 2004
I agree, you have to go out start the car and try to listen where the hissing is coming from. Its probably just a vaccum line that came off under the intake or something.
D
Daggar
3,902
  • Jul 21, 2004
You can start by running the engine then spraying some starting fluid around that area to see if the engine idles up. So long as everything is tight (meaning your throttle body out to your air cleaner etc.) then hearing the engine idle up is a sure indication that something is sucking that starting fluid in. If you don't get any change in the engine pitch (meaning that you don't have a vacume leak) then change your throttle position sensor. In that case, the sucking noise you hear is the motor trying to spin up and the throttle body not opening quick enough to keep up with it. You can also check this by disconnecting the intake hose from the throttle body then revving up with the throttle linkage. If you hear air being "sucked" past that throttle body then that's a pretty good indication that the sensor is whacked. That condition would also explain the rich fuel smell you're getting.
Whytry91
321
Morrisville, NC
Jul 21, 2004
  • Jul 21, 2004
off topic, but I saw he was a new guy so I thought I'd spruce up his avatar.
D
Daggar
3,902
  • Jul 21, 2004
hehehe... thanks... now is he not only a mindless killer, he's phsycho! lol
88mustangGT
298
#10
  • Jul 21, 2004
  • #10
defently a vacume hose poped off or cracked. it will cause you to run rich when that happens.
DTT92LX
185
Downingtown, PA
Jul 22, 2004
#11
  • Jul 22, 2004
  • #11
Just to tie up this thread...
Once the engine cooled off a bit I got my meaty paw up under the intake and found the vacuum leak. The hose on the left split at the nozzle. Its not the hose going around back the engine but the other, smaller, one going down to a box under the airbox. WOT module I think I've heard it called???
Thanks for the help.
89lxsport50
550
Franklin Tennessee
Jul 22, 2004
#12
  • Jul 22, 2004
  • #12
The small hose on the front of the intake goes to your charcoal cannister. The large one that goes around back is the PCV hose.
DTT92LX
185
Downingtown, PA
Jul 22, 2004
#13
  • Jul 22, 2004
  • #13
What's the charcoal canister do? Can it get clogged, 'cause now that I reattached the hose, a very old hose mind you, it's collapsing slightly under the vacuum. Up at the intake end. I'll put a new hose on but I'm just wonderin' if I have other problems that I should consider... Don't think the hose should really collapse unless there's blockage at the canister end...
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
