Blinker thing
  • Thread starter Thread starter streethorse
  • Start date Start date Dec 12, 2010
streethorse
1,042
Dallas Texas
Dec 12, 2010
  • Dec 12, 2010
Whats with this.... Left Blinker blinks fast, right blinker normal slow.
No lamps burnt out, front and back still work on both sides.
Az Pete
711
18
49
Panama City, Fl.
Dec 12, 2010
  • Dec 12, 2010
Double check the back.....should have two bulbs (stock) on each side for the rear turn signals. Turn on the emergency flashers and walk around the car to see if anything does not match side to side. The fast flash is an indication of a bulb not functioning.
stanmckinney
1,188
Dec 12, 2010
  • Dec 12, 2010
Correct. I had the same thing happen on a 2007 and had to replace the bulb.
streethorse
1,042
Dallas Texas
Dec 12, 2010
  • Dec 12, 2010
That was it ... the inner panel on the left rear.Thanks.
Az Pete
711
18
49
Panama City, Fl.
Dec 12, 2010
  • Dec 12, 2010
Never hurts to double check....glad you found the problem.
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
Help with running lights
  • 93CalypsoConvert
  • Nov 29, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 29, 2024
General karthief
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
