  • SN95 4.6L Mustang Tech
Blinking Battery Light :: Causes?
  • Thread starter Thread starter AmBo
  • Start date Start date May 3, 2005
AmBo
1,027
New Jersey
May 3, 2005
  • May 3, 2005
Hey, i posted about this some while ago but the thread got lost. Here is my dilemma:
My battery light likes to scare the piss out of me whenever it feels like it. No pattern at all, just comes on when it wants. I can't find a pattern! BUT I think it happens most when it rains or there is heavy moisture in the air?
I'm not draining much power from my alternator (800w kenwood amp and 12" kicker comp-v) but I want to blame the alternator. I have been noticing a lower idle as well but I want to blame something else for that.
What could cause this random "BLINKING" battery light? What should I check? Should I just bring this to the dealership? (GASP!)
Indiana
286
  • May 3, 2005
Make sure your battery cable connections are clean, as well as the connection to the alternator. You can buy a little battery terminal scrubber at the autparts store for a couple of bucks.
If you have a voltmeter, make sure your battery is around 13.4 + or - a little with the car off.
It should read 13.8 to 14.6 with the car running.
If you don't have a meter you can have the autoparts store check it for you when you go to get the terminal scrubber.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 3, 2005
  • May 3, 2005
Most parts stores can check battery voltage and alternator still in the car. It does sound like you are having charging problems but I'd try cleaning everything first as Indy suggested.
AmBo
1,027
New Jersey
May 3, 2005
  • May 3, 2005
Ok, so clean the terminals on the battery with a terminal scrubber from pepboys? I will do this and see if the problem persists. Thx!
Indiana
286
  • May 3, 2005
Make sure to have them check the batt and alternator while you're there.
AmBo
1,027
New Jersey
May 3, 2005
  • May 3, 2005
Oh, they can just run out and test it? Good deal. Watch em charge me $120 for the check. :-X
Indiana
286
  • May 3, 2005
Should take about 5 minutes and should be free.
twogts4us
4,188
12
79
Dunedin, FL
May 3, 2005
  • May 3, 2005
My 02 had the same exact problem you described..even the part about seeming to be a bit worse when wet or humid. Took it to Ford and on the first trip they replaced the batt...when it still was blinking, on the second trip to the service bay, they replaced the alt - problem solved...hasn't blinked in 5 months.
Likely it's your alt...
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
T
Resolved Signal light Issue
  • tonybigbaloney
  • Feb 20, 2024
3K
SN95 4.6L Mustang Tech Mar 7, 2024
tonybigbaloney
T
03 Gt battery issues while driving
  • ThatBlack4.6
  • Nov 17, 2023
2K
1996 - 2004 SN95 Mustang -General/Talk- Dec 1, 2023
Mustang5L5
Resolved Gauges and lights pulsing
  • sav22rem22
  • Sep 25, 2023
4K
Fox 5.0 Mustang Tech Oct 23, 2023
sav22rem22
F
Airbag Light
  • Fri Guy
  • May 3, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 13, 2022
Fri Guy
F
