Block Question
  • Thread starter Thread starter Black1987Stang
  • Start date Start date Dec 28, 2006
Black1987Stang
1,422
Jersey Shore
Dec 28, 2006
  • Dec 28, 2006
I plan on building up another motor for my stang when I start working, question is, I have a 1980 non roller motor in my shed right now, would this have anymore benefits than a 87-93 roller motor?. I was planning on either a 347 stroker, or rebuilding it up for boost. The block number on it above the starter is E0AE D3C...which Ive found out is a 1980 block from a Galaxy?.......Im not worried about converting it to roller, I just want to know which one might be better, if this one might be any stronger than a normal roller motor block basically.....
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Dec 28, 2006
  • Dec 28, 2006
Unless its was a mexican block, or an older Hi-po 289.. i dont see it being any CONSIDERABLY stronger than your 5.0l roller.
The extra effort of converting it to roller (if that is what u plan) wouldn't justify using the galaxy block vs the original 5.0l IMO.
Black1987Stang
1,422
Jersey Shore
Dec 30, 2006
  • Dec 30, 2006
thanks anyone else
89streetbeast
365
horton,ks
Dec 30, 2006
  • Dec 30, 2006
from all the research ive read through on blocks, the more seasoned it is, the stronger it is no matter what the higher nickel content is or the year.
if you find a roller block that has over 200k on it, its well seasoned and will handle as much as an R302 or Sportsman block. heat has alot to do with how strong the block is unless its cryonized. when a block comes from a fresh hot tank to get it cleaned its been seasoned on top of what the strength of the block was before it went in. virtually making it a stronger block.
this is what i have read so dont quote me on specifics with it.
txstang84
1,639
42
69
Tuscola, tx
Dec 30, 2006
  • Dec 30, 2006
I've talked to several machinists and racers alike on this one. All pre-'74 blocks have the "higher nickel" content. On that note, it's not like they were indestructable. Even mexican and 289 hi po blocks have their limits. The real strength from the earlier blocks comes from the blind tapped holes in the mains and in the decks, it's also due to the architecture of the main webbing, not the high nickel content-which is pretty much just a warm fuzzy.
Now, as far as the earlier blocks are concerned for strength, will they handle as much as a sportsman? Certainly. But an R302 or an A4 which are completely different animals, will handle over 1000hp, whereas most 2 bolt blocks-mexican, hi-po, and sportsman alike will split open at least 250-300 less than that.
Black1987Stang
1,422
Jersey Shore
Dec 31, 2006
  • Dec 31, 2006
I gotcha, so what do you think I should go with to build a stroker or boosted motor for? 1980 non roller block and just use a non roller cam (hydraulic lifters)....OR use a regular fox 302 roller block
txstang84
1,639
42
69
Tuscola, tx
Dec 31, 2006
  • Dec 31, 2006
depends on your power aspirations...if you really want to exceed 450rwhp and do it reliably, then maybe you should start saving for a 4 bolt block. At a bare minimum go with a pre '74 block for that power level. As far as that '80 block...I think I'd sooner use a later roller block, they're really the same strength, and at least you get to use a better cam...
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
