Block Smoking
  • Thread starter Thread starter 50foxbody
  • Start date Start date Oct 8, 2009
50foxbody
218
  • Oct 8, 2009
Ok i have had nothing but bad luck with this mustang since i bought it (3 months ago). the car sits but i start it atleast 2 days a week and let it run for about ten minutes.. today i drove it about 20 miles the car was running great smooth ride i was enjoying it but once i stopped i smelt something like a burning smell? and i popped the hood and smoke started to come up not too thick but it was white smoke and it came up around the block on both sides. i know the oil needs to be changed but i dont think that would cause it thanks for any ones help!
mc0311grunt
86
Los Angeles
Oct 8, 2009
  • Oct 8, 2009
is there a bunch of oil and crappola built up on the block? Freeze plug maybe?
95Vert383AOD
1,133
34
69
New Bedford, MA
Oct 8, 2009
  • Oct 8, 2009
leaking valve covers....if not that....the seal in the rear of the intake can leak. Feel if theres oil running down the back of the block. The valve covers are properly vented right?
STROKED_LX
43
  • Oct 8, 2009
White smoke most of the time means coolant burning off or steam if its grayish, but could be oil too, check for oil or coolant leaks dripping on to a hot surface and creating the smoke.
When the engine is cool look all around the engine, all the coolant Hoses, gasket area's, thermostat housing, valve cover, intake area.
Cobra912
1,777
11
39
Wish I was anywhere but here
Oct 10, 2009
  • Oct 10, 2009
I agree but I know when I had oil leaking from my breathers it created a thin white smoke as well. It may be oil or coolant. is the car leaving puddles??
50foxbody
218
  • Oct 11, 2009
there was alot of debree back behinde my intake so i took the time to scrape all the built up grease and oil off the engine and trans took it for another 20 min drive and everything is good
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Oct 11, 2009
  • Oct 11, 2009
Id change thoose valve cover gaskets..
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 11, 2009
  • Oct 11, 2009
#1: Find what is leaking
#2: Find where it is leaking
#3: Fix what is leaking where it is leaking
/problem
Most likely the valve covers or the lower intake. My stock intake is leaking coolant. That is fine because the edelbrock is sitting there ready to go on. Just want to get a larger TB first.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
