Fox Blower Motor Not Working
CAC Orange
I have an 88 LX and for a while there I had an intermittent issue with my blower motor not working, it would cut in and out. Now it has stopped all together.
  • I hot wired the motor and it works fine.
  • There is power at the fuse panel and the fuse is good.
  • There is power at the Selection (Panel, Mix, Off, Defrost, Floor) Switch (Black with Orange wire)
  • There is no power at the motor plug behind the glove box
  • There doesn't seem to be power at the speed selection switch via the Black wire
Does anyone have any experience with this issue? Is it the switch part itself, like an internal short between the Selection Switch and the Speed Switch? Or is the power at the Selection Switch completely independant from the Speed Switch?
Diagrams courtesy of Tmoss & Stang&2birds
A/C and Heater electrical wiring
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94-95 Mustang wiring diagrams
http://www.veryuseful.com/mustang/tech/engine/#95-95Diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Can't speak for an '88, but my '86 has a resistor for my blower. I'm guessing you have the same. They can go bad.
@jrichker will know.
Thanks for taking the time to answer my posting. I knew there was a resistor and it was a possibility that it could be the problem but I thought it was located on or in the blower motor casing which is after where I am not getting any power. I will look at the wiring diagram that you provided and take another look at it tomorrow.
Electrical issues are not something I have a lot of experience with, but I am determined not to pay someone to fix this problem
Thanks again for your help.
Reactions: Davedacarpainter
