I have a fan control I bought from O'reilly's HAYDEN, INC. - Cooling Fan Control
Item No: 3647. It didn't have as big as wiring as the 10 gauge I bought, but here is how I wired it:
One 10g wire from the solenoid to the control/relay, there is a 30a fuse on the control line there. From there it goes to the power on the fan with a 10g wire.
one 10g wire from the negative on the fan to the ground where the battery used to be.
One wire from the control to the 12v power on of the low coolant sensor. '
One ground from the control/relay to the battery ground.
Right now I don't have the a/c hooked up so that is all the wiring there is. There are about 5 different wires grounded to the battery ground. Only problem is it is just a self tapping screw holding all the wires onto the ground spot.
I bought a surge suppressor diode from radio shack and am going to wire that in, but I don't know how to connect it, as mentioned above to help, I assume with the pull of the fan when it starts up.
I was thinking about changing the ground on the fan to a spot over on the passenger side, but don't know if that would work or not. I mean, where could I ground to there?
