  • 1994 - 1995 Specific Tech
BLOWN AND STROKED
  • Thread starter Thread starter Yobi1Kanobi
  • Start date Start date Jan 24, 2006
  • 3
  • 4
1 of 4 Next Last
Yobi1Kanobi
559
  • Jan 24, 2006
IM BUILDING A 347 WITH FORGED KIETH BLACKS, HELLFIRE RING 4340 I BEAMS, 28 OZ BALANCE. STEEL MAIN GIRDLE
I HAVE TRICK FLOW TW HEADS AND R INTAKE,30# injectors and 65 mm TB
I THINK THIS MIGHT BE A SOLID BUILD, WITH MY POWERDYNE UNIT HUFFING 9#S
WHAT DO YOU THINK THIS WILL PUT OUT. WHAT SHOULD I LOOK FOR IN FUEL REQUIREMENTS,WHAT ARE THE OPINIONS ON THIS SET UP
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jan 24, 2006
  • Jan 24, 2006
One favor....caps off please.
That combo should run really well...might be a couple guys around here with something similar. My only words of advice would be to be careful of the block
Yobi1Kanobi
559
  • Jan 24, 2006
I got a good girdle for the block. But that stock block is going to have to hold. Boost is kept moderate and fuel is kept at hand it can hold.
Keeping up with the 500 horse club Z06,Shelby, and Cobras,
95CobraMike
1,046
Lima OH
Jan 24, 2006
  • Jan 24, 2006
What girdle do you have? can i buy it?
Yobi1Kanobi
559
  • Jan 24, 2006
I guess that was a cheap shot at my girdle, but you know people are out there runnin into the 500s with a stock block.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Jan 24, 2006
  • Jan 24, 2006
Not enough injector. You'll need atleast 42#'s, maybe 50's.
blksn955.o
3,263
st.louis mo 314
Jan 24, 2006
  • Jan 24, 2006
30's are prob a good choice without the blower...with it you will need more.
a 255lph intake and maybe a inline as well to be safe would be my choice for boost. .02
9
90_306powerhous
  • Jan 24, 2006
my brother is stroked and blown with the factory block and he hasn't had a problem yet"knock on wood". it will hold together if u don't abuse it. he put out 465 at 6600rpm. thats without the supercharger. he has a powerdyne with only 6psi. trust me this thing is quick. yesterday was the first time i drove it and its nice. when he was n/a he didn't have any power til 3500 rpm. now with the supercharger he has power down low and its nice.
he has a main girdle from dss. and a valley girdle. that is alot of extra strength. but again if u go out and raise hell all the time it will break.
sdc13
381
SoCal
Jan 24, 2006
  • Jan 24, 2006
Post dyno #'s when you get that set up completed. I'm doing a 347 with AFR 185's and Novi 2000 this summer. I think 450rwhp should be no problem. Good luck.
91LX_5L
1,943
British Columbia
Jan 24, 2006
#10
  • Jan 24, 2006
  • #10
wow sounds killer keep us posted
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jan 25, 2006
#11
  • Jan 25, 2006
  • #11
Where in Miami are you?
Is a shop doing it or you?
RC
mytight95
2,605
Dothan,Al
Jan 25, 2006
#12
  • Jan 25, 2006
  • #12
i didn't know keith black made forged pistons?
jason
Killercanary
The car that set the bar.
Altoona, PA
Jan 25, 2006
#13
  • Jan 25, 2006
  • #13
450rwhp should be EASILY attained, but I'd be VERY surprised if you didn't eclipse that easily. For fuel, as Joe said you'll need at a minimum 42's, but 55 or larger would be my suggestion. You will also need at a minimum a 255 high pressure intank and a high flow inline pump as well. It will need tuned too.
Believe what you want, but I'd be cringing everytime I was into the throttle if I had that combo, or the other listed running that kind of power due to the block. They are weak and due to the thin cast walls. After you get it together I'd start a fund for a better block IMO.
Joes95GT
3,132
Delaware
Jan 25, 2006
#14
  • Jan 25, 2006
  • #14
Amen!
If anyone thinks that they are going to be in the 450 RWHP range with a H/C/I 347 and 9 PSI, they should probably find another person to build their motor or tune their car. That combo should make an EASY 500 to the tires....
Joe
Yobi1Kanobi
559
#15
  • Jan 25, 2006
  • #15
:SNSign: I already purchased the inline fuel pump. I have a 190 lph in tank now which will be there untill i add the blower. Aluminum Fuel rails to feed the beast. MESA BALANCING in miami should be doing the build. he is reputable I currently had my car tuned by WILLIE Diablo sport he does hell of a good job tuning he was the only one who was able to tune my old setup in a drivable state.
Do you think the 190 with the 30#ers will be enough for the 347?
When will the blower be safe to install on a fresh 347.
Yobi1Kanobi
559
#16
  • Jan 25, 2006
  • #16
KIETH BLACK FORDGED is new in the line up I think its a quality piece KB hypers are the best hypers you can get so they must be good forged pistons
94GTLaserRC
11,178
Jan 26, 2006
#17
  • Jan 26, 2006
  • #17
RC
Redsnake2
374
Philly, PA
Jan 26, 2006
#18
  • Jan 26, 2006
  • #18
As stated a million times before, get a set of 42's and install that 255Lbs intank.. I'm in the same frame of mind with building a twin turbo set-up with a stock block. Think I'm going to have to reduce my block to scrap metal until someone drop 2 grand in my lap for a new block.
boostaddict5_0
37
#19
  • Jan 26, 2006
  • #19
I'm with Red...Go with either 42lber's or 55's. Get the 255lph fuel pump and a Fuel Pressure Reg.
Yobi1Kanobi
559
#20
  • Jan 26, 2006
  • #20
The car is in Hialeah. I live in Sunrise.:OT:
  • 3
  • 4
1 of 4 Next Last
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
