  • 1994 - 1995 Specific Tech
BLOWN AND STROKED
  • Thread starter Thread starter Yobi1Kanobi
  • Start date Start date Jan 24, 2006
  • 3
  • 4
First Prev 2 of 4 Next Last
Yobi1Kanobi
559
#21
  • Jan 26, 2006
  • #21
I plan on getting bigger injectors maybe 55 to keep it on the richer side. I do have an fmu but i might not install it due to that people say its not that realiable.
As far as the block is Concern i Guess its easy to say to just buy a new dart block but that is the cost of my whole project there 2500 for the block plus the machine work to prep the raw engine. I will know that is my weakest link at the moment and willl try to keep the power in the mid 400s I aint even going to run the extra 25 shot of spray i was planing. I already have the NOS dry kit so I was going to leave that on for good measure but that will just have to hit ebay instead of my engine bay.
mytight95
2,605
Dothan,Al
Jan 26, 2006
#22
  • Jan 26, 2006
  • #22
yobi1kanobi said:
KIETH BLACK FORDGED is new in the line up I think its a quality piece KB hypers are the best hypers you can get so they must be good forged pistons
Wasn't being smart, but i will look for some now, i am soon to start my motor.....
A mexican block would be vast improvement in your case...i saw one on corra for 450 the other day, still standard bore....could be bored and cleaned up easily... just a heads up..cause if you get everything you listed above, you will need a good block, or as PAUL said, a soft foot
On the fuel pump, i would run a 255, and an inline with boost to be sure.......
jason
Yobi1Kanobi
559
#23
  • Jan 26, 2006
  • #23
I purchased all my parts from Pro Power in ft. lauderdale
they carry they KB forged. the girdle is a CANTON steel piece. I will be changing my pump to a 255 and the t-rex inline when i add the blower in the mix but for the 347 the 190 and the 30# inj should work unless some thinks otherwise. As far as the mexican block i havent had much luck finding those since they have been out of production for a while. And the sportsmans are about 1000 bucks. and i aint even going to start with the DARTS. and since I aint really planing on beating the holy crisis out of the thing. plus like i said before i will limit the output and the rpms.
MattZ281LE
345
Purcellville, Va
Jan 26, 2006
#24
  • Jan 26, 2006
  • #24
I am making 625 at the back tires on a stroker and T-Trim.
Do the fuel right.
Limit the RPM's (under 6k)
Use a mild cam.
Conservative tune
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jan 27, 2006
#25
  • Jan 27, 2006
  • #25
Got a # and/or address of this shop?
Do they build and install engines too?
Maybe Ill see you at Towers sometime.
RC
ProKiller
3,064
15
78
PA
Jan 27, 2006
#26
  • Jan 27, 2006
  • #26
TUNE! and make sure your ignition system is up-to-par. that was my problem. the whole time it thought it was not enough fuel and it was my distributor taking a crap.
Yobi1Kanobi
559
#27
  • Jan 27, 2006
  • #27
I have a Crane hi6 box for ignition with a map sensor that i can use but i think i might let the chip work the timing...as far as distributors let see what ebay has at the time????????
Yobi1Kanobi
559
#28
  • Jan 27, 2006
  • #28
Getting a 3 angle valve job and the heads cleaned up.
what do you think about a custom cam would that be a vast improvement over my trick flow stage one now
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Jan 28, 2006
#29
  • Jan 28, 2006
  • #29
90_306powerhous said:
he put out 465 at 6600rpm. thats without the supercharger.
id really like the specs of that combo.....
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 28, 2006
#30
  • Jan 28, 2006
  • #30
What are you going to do about a maf?
Why only a 65mm tb?
Grady
Joes95GT
3,132
Delaware
Jan 28, 2006
#31
  • Jan 28, 2006
  • #31
Why only a 65mm tb?
Grady
C'mon Grady?!
Better velocity!!!
Joe
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jan 28, 2006
#32
  • Jan 28, 2006
  • #32
Joes95GT said:
C'mon Grady?!
Better velocity!!!
Joe
It has taken a while for an old carb guy to see that all you young pups may have the right idea about these new fangled air only intake devices
Grady
Yobi1Kanobi
559
#33
  • Jan 28, 2006
  • #33
Set up Break down Mechanical
Hope This explains my setup for those of you curious.This does not include any cosmetics like rim,tires,spoiler,stereo,etc...
9 to 1 compression KB forged piston
I beam rods
hellfire plasma rings
Main cap Girdle
Windage tray
HV oil pump
7 qt pan
28 oz balnce Flywheel and SFI dampner.
Trick Flow R intake
Trick Flow Heads 3 angle port -cleaned up
Trick Flow Stage 1 Cam
Hi-6 crane ingnition
Summit Distributor
30# injectors ---upgrading after break in period to 42
75 mm MAF Pro-M (i am curious about doing the lightning swap)
65mm TB
DIABLO Chip custom tune
POWERDYNE 9#
3.73 gear
aluminum drive shaft
subframe connectors
upper and lower control arms
Tokico shocks and Springs
t-5 Promotion built probably checking out soon
King Cobra Clutch will upgrade with new tranny
(if the clutch engages softer its easier on the drive train):OT:
maybe 25 shot of NOS to cool things down
94GTLaserRC
11,178
Jan 28, 2006
#34
  • Jan 28, 2006
  • #34
Grady
WERD!!
RC
4Jenna
4,326
AZ
Jan 29, 2006
#35
  • Jan 29, 2006
  • #35
Dont skimp on the fuel..seems you need to do ALOT more homework.
Yobi1Kanobi
559
#36
  • Jan 29, 2006
  • #36
I am droping a 225 in the tank, inline t-rex, alum steeda fuel rails, and 42# inj. so i dont know what else i can need for the supercharger ..i have done my Home work and that seems suffice if you think otherwise let me know. I am gonna go thru the break in with the 190 intank and 30# inj since it will be a 347 N/A...
:OT: Took engine out today my original pistons look great. A little pitting on the crown probably becuz of the NOS. cylinder wall look clean MOBIL 1 is definitely worth the money. I did have a smoked clutch. I guess thats a good thing since i need a new clutch to hold the horsepower.
Any suggestions....
4Jenna
4,326
AZ
Jan 29, 2006
#37
  • Jan 29, 2006
  • #37
WTF does that mean...valve job, or port work?
Yobi1Kanobi
559
#38
  • Jan 29, 2006
  • #38
the heads will be cleaned up as ports are concerned just smooth out the edges and the valve job being seperate just 3 angle job u know what that is?.. eades50 if you dont have any good input or anything good to say stay the f@#k out of my post..
4Jenna
4,326
AZ
Jan 29, 2006
#39
  • Jan 29, 2006
  • #39
Just seems you are in way over your head is all
4Jenna
4,326
AZ
Jan 29, 2006
#40
  • Jan 29, 2006
  • #40
3 angle valve job...no i dont..enlighten me
  • 3
  • 4
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
