http://www.fi-r.net/images2/mustangpics/NoviMustangTrackNight.wmv
Went to the track Saturday evening.. I made a best pass of 12.60 @ 111mph, and my best trap speed was a hair under 113 (112.92). Best 60ft was 1.887. Yes, I know that's horrible.. but, with the 3.27's and the 6spd.. I couldn't get off of the line for squat.. I was dumping the clutch at 5K rpm, and STILL bogging the hell out of the car. I crossed the line at around 5500 in 3rd gear! I did manage to yank a 6 liter GTO with DR's out of the hole (in the video), and I beat my friend's Lightning a few times.. he was running some 27x10" slicks, so he got the holeshot, but, I would reel him in by the 1000ft mark every time..
So, needless to say.. I need to install my 4.10's.. I wonder what the car would do on a set of slicks, with better gearing? I'd say high 11's for sure..
Just to clarify.. I have installed..
Novi 2000 head unit/bracket
Custom bar/plate intercooler setup
Custom 3" aluminum piping
Tial Raptor blow off valve
80mm Lmaf
42lb injectors
BAP
SCT self tune (racer software, 14* timing and around 11.2-11.5:1 A/F on pump)
VRS x-pipe
Magnaflow catback
Viper spec T56
Fidanza aluminum flywheel
Spec 3.5 cluch
Stock 8.8 (3.27 ratio)
Custom plates for torque boxes
Steeda upper/lower control arms
Custom subframe connectors
I see right at 7.5psi of boost after the intercooler/piping (measured at the plenum). I'm still on a bone stock windsor motor (2000 model), with right at 80K on the ticker.. I'm hoping to swap in my built teksid bottom end soon.. maybe this fall.. I have a bigger MAF and 55lb injectors ready to go in.. just need to get the built bottom end finished..
Travis
80mm Lmaf
42lb injectors
BAP
VRS x-pipe
Magnaflow catback
Viper spec T56
Spec 3.5 cluch
Travis
Some 4.10s will really help wake up that tall first gear in your T56
But, nonetheless, I made it home, and I'm heading to ford tomorrow for a new alternator. I cut a 1.81 60ft.. which kinda sucks.. I'm still on stock rear suspension.. so I got a little bit of wheelhop before it hooked up. I guess some coilovers will be next on the list..
