  • 1994 - 1995 Specific Tech
Blown head gaskets :) need a quick answer
  • Thread starter Thread starter Yellow302
  • Start date Start date Nov 8, 2007
First Prev 2 of 2
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 11, 2007
#21
  • Nov 11, 2007
  • #21
Rick, mind if I ask why you use the RTV versus Permatex Blue? I believe that's what TFS recommended when I installed my heads, so that's what I used with the ARP studs. It is hardening, so it should work in the same manner as the RTV, right? Or do you just like the RTV because it's thicker, and will consistantly seal?
Yellow302
789
NJ
Nov 11, 2007
#22
  • Nov 11, 2007
  • #22
well the car is back together and 1 heat cycle now, should i heat it up 1 more time before i retorqu the lower intake?
BlownFiveLiter
18
108
Chicagoland
Nov 11, 2007
#23
  • Nov 11, 2007
  • #23
It couldn't hurt. I never retorqued my lower after I installed it, and it's had probably a couple hundred heat cycles now. Just torqued it down in sequence until it stayed at the correct torque and left it at that.
Yellow302
789
NJ
Nov 11, 2007
#24
  • Nov 11, 2007
  • #24
damn heater rail is leaking from the part right above where it screws into the lower. There is nothing i can do there i think. I loaded it up with some sealer and letting it sit over night... its always something...
Rick 91GT
Mustang Master
95
99
PA
Nov 12, 2007
#25
  • Nov 12, 2007
  • #25
Permatex Blue, Red, Copper, Grey and Black will all work. I personally use the Black.
First Prev 2 of 2
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
