Blue/red Wire. Instrument Cluster Back Light.
B.erazo712
235
46
48
Last week, my instrument cluster light went out, so I pulled apart my dash today to see. Took out my test light and checked all the fuses, and the 5 amp fuse wasn't lighting up, switched the fuse out and nothing. Tried it with the key on/off, lights turned on/off, still nothing. I followed the blue/red wire on the back of the fuse box and I cant really see where its going under the dash, but i see it connects to the back of the instrument cluster, and the headlight switch. I know it has something to do with that wire, just not sure on how to approach this with the dash in the way. Not to mention its tangled in the 100 other wires behind the fuse box. I've tried looking at wiring diagrams, but doesn't show much about it. Any one got an idea on what to do?
Also does anyone know the name of the rod that goes in this?
https://lmr.com/item/LRS-50600A/83-93-Mustang-Hydraulic-Cylinder-For-Convertible-Top
735c12cc4c5a3f5e882c9ab91176aabe
767ca4d8e4c80f7d75cfdefcfd5b412b
f18d250f5d6e7d3a98fb0abef09abef5
Dimmer & Dome light
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
I see the blue/red wire behind the radio, but it was taped off? The fuse isn't blowing and all the wires on the back of the headlight switch are working except the blue/red wire. The only thing I can think of is the ground is bad, but I'm not too sure where the ground is?
If it helps I also have the white face gauges not the stock ones. The wiring taps into the blue/red wire behind the headlight switch and a ground wire that also connects to the headlight switch.
