  • Mustang Sound & Shine All
Body work anyone?
  • Thread starter Thread starter KENS89LX
  • Start date Start date May 11, 2007
KENS89LX
302
Cross lanes Wv
May 11, 2007
  • May 11, 2007
I am starting to sand on my 89 and need to know what grit of sandpaper to use, it has been painted 3 times so it is pretty thick I want to go to the metal.
G
getusummm
156
  • May 14, 2007
aircraft stripper. you will come out cheaper in the long run.
4G-KDMP
935
CA
May 15, 2007
  • May 15, 2007
if you use the aircraft stripper just be prepared for a gunky mess when the paint is stripped off.
87foxstang
Cromwell, CT
May 31, 2007
  • May 31, 2007
180 grip would take it down pretty quick, you could go even courser, but you will leave some serious scratches to be filled
stovetop25
  • Jun 9, 2007
If you are stripping the car to bare metal, once you have stripped all the paint you should apply 2 coats of Epoxy primer and give it enough time to properly dry before applying anything else to the body (ie. body filler). If you want a good Epoxy primer, search for a company called SPI, they make some good products.
Turbo92PGT
746
Auburn Washington
Jun 10, 2007
  • Jun 10, 2007
just use 80 grit on a DA.
When you get all the paint off like u want. run 180 over the metal on your DA.
There are a couple ways to do it. If you're gonna strip your paint to metal and leave it a while put epoxy on it.
Or do your bodywork then put epoxy over it
let that dry and put 3-4 coats of urethane primer
Just depends how you wanna do it.
No offense but if you're asking what to strip it with, chances are its nearly your first time and you probably are mostly concerned with it just looking nice and shiny again.
If thats the case just do your bodywork and put some urethane primer on it and paint that bitch lol
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
Mustang Sound & Shine All Tuesday at 12:29 PM
NotaVegetarian
N
F
Need body/paint shop in san jose area
  • FordFan
  • Nov 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 21, 2025
WTB Oxford white hood, bumper and fender for LX foxbody
  • keel
  • Jan 7, 2026
  • Want to Buy
Want to Buy Jan 7, 2026
keel
Foxbody Intro
  • 5.0Sucio
  • May 26, 2026
  • The Welcome Wagon
The Welcome Wagon May 26, 2026
