  • SN95 4.6L Mustang Tech
Bogging down ????
  • Thread starter Thread starter shadowstang03
  • Start date Start date Jun 10, 2004
shadowstang03
26
San Marcos TX
Jun 10, 2004
  • Jun 10, 2004
Does anyone have the problem of when you take off at the track or just foolin around when you punch it from a standing start and the motor seems to lag some and then take off?? I have an 03 GT and the problem happens at the worst times you know what I mean. Its always in first gear any ideas what this is or how it can be fixed???
R
Red2000GT
2,450
Regina,Sask.Canada
Jun 10, 2004
  • Jun 10, 2004
I noticed it but only because I came from an 88GT with 3.73's and a bunch of bolt ons. The 4.6 isn't a huge torque producer like the 5.0 was. I see that you're having gears put in as well and that should help out alot. Also you might want to consider getting a timing adjuster,they've been shown to add up to 15 ft-lbs on the bottom end.
KaPPaBaLL
1,326
BAYAREA
Jun 10, 2004
  • Jun 10, 2004
quit dumping your clutch to launch..
F
flexiclese
85
Pearland, TX
Jun 11, 2004
  • Jun 11, 2004
yes,
My '03 GT just started doing this at about 18,000 mi. Stomp on the go pedal and it takes a split second to respond. It didn't used to to do this either. I changed my fuel and air filters and it still does it. I haven't notice a decrease in gas milage though. I was wondering if maybe I had bent or dented an exhaust pipe and not noticed, but I saw nothing when I got underneath the car. It doesn't do it all the time either, Only when I really lay into it. I'm curious to see if more people have experienced this.
Dave
Bulldog6Z6
163
Houston Texas
Jun 11, 2004
  • Jun 11, 2004
maybe instead of getting the 70mm t/b you should get a timing adjustor it helps a good amount in low end.
D
damien2003gt
181
  • Jun 11, 2004
Ummm... Do ya have your traction control turned of?
shadowstang03
26
San Marcos TX
Jun 11, 2004
  • Jun 11, 2004
YES the traction control is off... any ideas how to fix ???or what it is????
Modular2v
3,222
23
99
oklahoma
Jun 11, 2004
  • Jun 11, 2004
mine did the same thing and it turns out i blew the clutches in my rear so an eaton took care of that!!!!!!
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
