bolt sizes!!
nfsdriver01
hi, i am new to teh forums here so iw ill give a brief intro before i get to my problems. i own a 1989 hatch lx. its in pieces but coming along. i also own a 07 v6 stang with a 5spd. its stock at the moment other then the gt spoiler i bolted on.
now on to my problem. i just finished rebuilding the engine and am getting ready to put it back in the car. i bolt a bolt kit off ebay which has been great but was only really helped with inatek and headers and other bolt on stuff. it did not include new bolts for the motor mounts and bell housing ect. i have managed to find most of teh bolts i need at home depot. i wanted the new bolts rather than using the old because with the fresh paint and all the new parts i didnt want the old crummy bolts plus when i got the engine some one else had the engine apart and re assembled it with what ever bolts they had. anyways if any one knows the following sizes, thread type and length or any info at all of the following bolts it would be great.
6 bell housing bolts
fan bolts that bolts on to the water pump (4 small bolts)
motor mount bolts
thanks again!
do you know what grade bolts you're getting from home depot? I always go to tractor supply or sears hardware to get grade 5 or grade 8 bolts (I use 8's for all suspension an power train items). go to a u pull it an get one of each an go match them to new ones.
Here is what I have, but you may need a confirmation.
Motor mount to block bolts - 7/16" x 14 x .88"
Bellhousing to transmission - M12 x 44.5mm
Bellhousing to block - 7/16" x 14 x 1.5-2.0"
That could get you started.
Thread width x Pitch (threads per inch) x Length
